Car wont stay running!?! - Honda Forum : Honda and Acura Car Forums
Wheel & Tire Center
Old 01-02-2010, 03:24 PM   #1 (permalink)
Car: 95 Civic
Mods: gsr swap, eagle rods, arias pistons, JR supercharger
gsrhtch is on a distinguished road
I have a basemodel 95 Civic with a grs swap and a jackson racing sc. I was driving it the other day, parked it for about an hour, tried to crank it again and it wont stay running. It will try crank up and run but it immediatly dies. All the lights work, fuel pump is priming, relay is clicking.... Im lost and dont know what to ty next. Ive went through all the fuses under the dash and none are blown.
The other part is wierd so Im going to try to describe it the best way I can. On the ignition, when I turn the key it has to be positioned between acc and on. I literally have to hold the key right before the on switch for the fuel pump to prime. Any ideas??
LOOKING FOR A CLEAN EG HATCH SHELL
gsrhtch is offline
Old 01-02-2010, 04:11 PM   #2 (permalink)
Iron Monk
MortsAccord's Avatar
Car: 1997 Honda Accord EX
MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?MortsAccord you're still here?
if yoo\u hold the ignition switch forward slightlky after starting the car as you described in your previous post, will the car stay running?
If not id check for vacuum leaks. If there are none id check fuel pressure
http://www.angelfire.com/games/marshallmort/Oil.pdf
AWSOME tech articles for FREE, get educated on some REAL information.
currently down.
http://www.bcae1.com
Everything you ever need to know about auto lighting:.
http://www.danielsternlighting.com/tech/tech.html
MortsAccord is offline
Old 01-02-2010, 04:28 PM   #3 (permalink)
Car: 95 Civic
In order for it to stay runnning I have to keep holding the key and give it gas
gsrhtch is offline
Old 01-03-2010, 11:18 AM   #4 (permalink)
Car: 95 Civic
Does anybody think it could be a bad ignition switch?
gsrhtch is offline
Old 01-03-2010, 12:17 PM   #5 (permalink)
Iron Monk
if it was ignition, there would be a lot of unburnt fuel, which would stink.
I'm betting its starved for fuel, pull your spark plugs and have a look at them to see if they are fouled up just to make sure its not them.
currently down.
Old 01-03-2010, 06:40 PM   #6 (permalink)
Car: 1995 Accord EX SDN, 1994 Acura Integra CPE
Mods: Accord: (Intake, Soundsystem, Power Outlet, VTAK Indicator) Integra: (Stock)
InfamousSabre has a Rep problemInfamousSabre has a Rep problemInfamousSabre has a Rep problemInfamousSabre has a Rep problemInfamousSabre has a Rep problemInfamousSabre has a Rep problemInfamousSabre has a Rep problemInfamousSabre has a Rep problemInfamousSabre has a Rep problemInfamousSabre has a Rep problemInfamousSabre has a Rep problem
Yes it is your ignition switch.
Ignition, meaning, the thing you put your key in. Not what makes spark in the engine.
InfamousSabre is offline
Old 01-03-2010, 07:09 PM   #7 (permalink)
Iron Monk
I dunno if its just his ignition because he said this.
The having to give it gas reminds me of a vacuum leak somewhere, and the problem staying running after turning the engine over is the ignition switch(we had one go bad at work on the fork lift.)
It may be both.
currently down.
Old 01-04-2010, 04:22 PM   #8 (permalink)
Car: 95 Civic
im going to mess with it some more and let you guys know what happens. This gives me a reason to drive the Nissan Silvia around
gsrhtch is offline
Old 01-08-2010, 10:10 PM   #9 (permalink)
You have a silvia and youre bothering with a honda that is giving u issues?
Maybe ill get flamed for this on a honda forum, but, i would just get rid of the honda.
<3 the silvia, and looking at a 300zxTT right now
yea i didnt read the holding the gas part, but hey! At least he could get from stoplight to stoplight! xD
Old 01-10-2010, 12:20 PM   #10 (permalink)
Car: 95 Civic
Yeah I know. But I love my Honda too. I can drive this car around all day, beat up on v8s, and drive it back home without a problem. This car has been built this way for over a year now and this is the only problem it has given me.
gsrhtch is offline
Old 01-11-2010, 10:48 AM   #11 (permalink)
Archadian's Avatar
Car: 94 Accord EX
Mods: Megan catback Konig 17", cold air intake, JDM headlights, Function Form Type Two Coils, H22A4 conversion, High flow cat
Archadian Hello down there miniscule peonsArchadian Hello down there miniscule peonsArchadian Hello down there miniscule peonsArchadian Hello down there miniscule peonsArchadian Hello down there miniscule peonsArchadian Hello down there miniscule peonsArchadian Hello down there miniscule peonsArchadian Hello down there miniscule peonsArchadian Hello down there miniscule peonsArchadian Hello down there miniscule peonsArchadian Hello down there miniscule peons
reading the part about the gas, i could agree that it could be a vaccum or fuel pressure problem, but the holding ignition hmm, that couldnt hurt to be looked at either
Archadian is offline
