Old 07-03-2002, 05:51 PM   #1 (permalink)
twiztidintegra is an unknown quantity at this point
Check Engine Light came on???
I need some help, I changed my battery yesterday because the other one died, and I just noticed the Check Engine light came on. Is that normal when the battery gets changed or can someone help me out. Is there a way to tell? I called the dealership, and the guy was like I can reset it for $80, and check to see the problem for $80, and that's too much. So I was wondering if there was another way. Thanks
twiztidintegra is offline
Old 07-03-2002, 10:15 PM   #2 (permalink)
Rayman is an unknown quantity at this point
Changing the battery shouldn't affect anything. See what code your car's throwing out to see why the check engine light's on.
95 Integra GS-R
Rayman is offline
Old 07-03-2002, 10:42 PM   #3 (permalink)
how do I check the code that's coming from the light?
Old 07-03-2002, 10:56 PM   #4 (permalink)
Car: 92 Integra GS-R
Mods: Blah.....
Louie55 is an unknown quantity at this point
u can just reset it by takeing off the neg. battery terminal for 10 min. (make sure u got the codes for radio etc.). then hook it back on and start ur car with everything turned off (radio, lights etc). DO NOT step on the gas. just let it run for 10 min and turn it off. then turn it on and ur ecu is reset. to check the CEL u have to jump the 2 pin grey connector under the passenger side knee panel and just count the blinks for the code.
P.S. dealers always try to rob u.
Louie55 is offline
Old 07-04-2002, 09:55 AM   #5 (permalink)
SlapSmak is an unknown quantity at this point
or you can reset the CEL like it is supposed to be reset by looking under your dash where the steerring wheel goes undernieth the panel. you will see a little blue square button. turn the key to the ignition on position and press the button in until it turns the cel light off. turn the key to the off position and then start the engine. Then buy a helms manual and learn a little about your car.
2000-DC2R PY 00319
JDM DC 4-1 SS
SMS Custom Race Cat
ShortRam
Goodridge SS Lines motul 600
Hawk HP+ pads
B&M shift kit
SlapSmak is offline
Old 07-04-2002, 11:14 AM   #6 (permalink)
Car: 00 Teg GS
mrhonda_187 is an unknown quantity at this point
That's for the Maintenance Required light.
Here:
http://www.bseries.net/html/garage/engcode.php
And the codes...
http://www.c-speedracing.com/faq/05.html
Sorry if those links get ****'d out.
00 Teg GS
mrhonda_187 is offline
Old 07-05-2002, 07:40 AM   #7 (permalink)
actually that clears the check engine light . it is the same light.
and to top it off, if you are kicking a code and reset the ecu but dont fix the problem, the code will come right back again
2000-DC2R PY 00319
JDM DC 4-1 SS
SMS Custom Race Cat
ShortRam
Hawk HP+ pads
B&M shift kit
SlapSmak is offline
Old 07-05-2002, 08:11 AM   #8 (permalink)
Car: 00 Teg GS
Doing what you suggested 'may' clear both lights, but let's clarify that these are two (2) completely seperate lights.
00 Teg GS
Old 07-06-2002, 10:59 PM   #9 (permalink)
GunMetal Member
Car: 2000 Integra LS
Integra2000LS is on a distinguished road
They are two different lights... As far as resetting your ECU you don't need to take it off for ten minutes to get rid of the CEL, just take it off leave it off for like 5 secs and put it back on and then start your car and run it till the fan kicks in, don't step on the gas. I have reset my ECU a number of times because of my test pipe and that's all I do and it works everytime to get rid of the CEL. But do make sure you check to see what code your throwing before you reset it.
2000 Black Integra LS
AEM - CAI
AEM - Underdrive Pullies
DC-Sports - 4-1 Header
DC-Sports - Short Throw Shifter
5 Zigen - Cat Back Exhaust
TestPipe.com - 2.25" Test Pipe
Skunk2 - OBD2/OBD1 Conversion
95LS P75 OBD1 ECU
EBC - Redstuff Brake Pads
Mugen - 8 Point Front Strut Tower Bar
OBX - 4 Point Rear Strut Tower Bar
Neuspeed - Sport Springs
Rota - 17" Gunmetal Subzeros
Tunes!!
Kenwood - KDC-X969 (Radio)
Kenwood - KTC-SR901 (Sirius Satelite)
Alpine - SPS170A 6.5 TypeS (Speakers)
Integra2000LS is offline
Old 02-06-2006, 07:18 AM   #10 (permalink)
tyler6453 is an unknown quantity at this point
Actually the same thing happened to me regarding the battery. I was changing out my radio and my battery died. I jumped it and about an hour later my check engine light came on. The acura dealership near me said that if the battery gets too low the check engine light will come on.
so hope that helps...
tyler6453 is offline
Old 02-06-2006, 07:46 AM   #11 (permalink)
Car: 1997 Acura Integra GS_R
A_White_GS-R has a reputation beyond reputeA_White_GS-R has a reputation beyond reputeA_White_GS-R has a reputation beyond reputeA_White_GS-R has a reputation beyond reputeA_White_GS-R has a reputation beyond reputeA_White_GS-R has a reputation beyond reputeA_White_GS-R has a reputation beyond reputeA_White_GS-R has a reputation beyond reputeA_White_GS-R has a reputation beyond reputeA_White_GS-R has a reputation beyond reputeA_White_GS-R has a reputation beyond repute
Dude its a four year old thread im almost positive he either figured it out or sold the car already.
A_White_GS-R is offline
Old 02-06-2006, 10:59 AM   #12 (permalink)
WVU97GS-R's Avatar
Car: 1989 240sx
haha lmfao, go easy on the noob atleast we know he was searching old posts for info ;-)
= SLOW!!!
Originally Posted by Franky299 View Post
WVU97GS-R is offline
Old 02-06-2006, 03:09 PM   #13 (permalink)
I give praise for the search. Just merely pointing out the fact so when he and others look they know to check dates of threads before bumping them back from the abyss.
Old 02-06-2006, 05:56 PM   #14 (permalink)
DaPunisher is a jewel in the roughDaPunisher is a jewel in the roughDaPunisher is a jewel in the roughDaPunisher is a jewel in the rough
eyyy... i know its a OLD ass thread but ppl are talkin about jumping codes so i was wondering if anybody knew how to do it on a 3rd gen jetta? i checked under the passanger side and theres no lil blue thing like on c-speedracing .com and somebody told me to take out the ashtray and i didnt find anything there either, maybe i didnt look right or maybe its somewhere else but i want to figure it out, any suggestions?
DaPunisher is offline
Old 02-07-2006, 12:44 PM   #15 (permalink)
Diff car manufacturer, different method. Its not a universal thing. You may want to check with the VW crowd.
female four is offline
