Originally Posted by tegrocket
Hey thanks for the reply, I got this kit from summit part no: RAM-88830. It includes the clutch, pressure plate, and throwout bearing but it does not come with the pilot bearing. How important is the pilot bearing to replace?
The pilot bearing is a small bushing that is mounted in the crank. This holds in place and keeps the transmission centered to the engine. If the kit comes with an alignment tool, one end of the alignment tool goes into the pilot bearing and the other into the clutch.
Pilot bearings are inexpensive and are important.
Here's the thing, if you pull your tranny to replace all the other parts, why not replace a $10 bearing. If you do not do it at the same time, you may be pulling your tranny out again in a few months just to replace it. Saves time and money in the long run.
Most kits come with the bearing. I see the
Ram does not. Nothing wrong with Summitracing, have given them lots of my money
If you are staying stock, here is a good kit from a good seller ->
Clutchcityonline (ebay).
