Compression Test Went Wrong
Well this sucks balls. So I am doing my compression test right, because I have that little bit of coolant leaking from the corner of the head/block. So I took the leads off, took the plugs out, put the tester in the first cylinder and then decided to take the electrical coupling off the injectors. Well, I do the compression test, all goes well. Then I put it back together, go to start it and guess what??? yah, doesnt start. I re set the ecu and nothing. I guess I should have grounded the ignition system or something cause now I have no spark. I am about to test the Coil and ICM. It is friday have to drive home sunday so I need to get the parts today. Please if anyone has anything to say, say it. I guess I learned a lesson tho. I will keep you guys up dated.
-I slightly pressed the throttle dipping my toes into the deep ocean of power this engine makes
