Old 06-13-2008, 01:26 PM   #1 (permalink)
Shafto's Avatar
Car: 1997 Acura Integra
Mods: Nada
Shafto has a Rep problemShafto has a Rep problemShafto has a Rep problemShafto has a Rep problemShafto has a Rep problemShafto has a Rep problemShafto has a Rep problemShafto has a Rep problemShafto has a Rep problemShafto has a Rep problemShafto has a Rep problem
Compression Test Went Wrong
Well this sucks balls. So I am doing my compression test right, because I have that little bit of coolant leaking from the corner of the head/block. So I took the leads off, took the plugs out, put the tester in the first cylinder and then decided to take the electrical coupling off the injectors. Well, I do the compression test, all goes well. Then I put it back together, go to start it and guess what??? yah, doesnt start. I re set the ecu and nothing. I guess I should have grounded the ignition system or something cause now I have no spark. I am about to test the Coil and ICM. It is friday have to drive home sunday so I need to get the parts today. Please if anyone has anything to say, say it. I guess I learned a lesson tho. I will keep you guys up dated.
-I slightly pressed the throttle dipping my toes into the deep ocean of power this engine makes
Shafto is offline
Old 06-29-2008, 03:28 AM   #2 (permalink)
speed=$ is infamous around these partsspeed=$ is infamous around these partsspeed=$ is infamous around these partsspeed=$ is infamous around these parts
Sounds like you forgot to plug one of the connectors in. Recheck everything.
speed=$ is offline
Old 06-30-2008, 11:48 AM   #3 (permalink)
Shafto's Avatar
Mods: Nada
no man, I blew my coil. I didnt disconnect the distributor so it had nothing to discharge to. so the coil didnt like that at all. I learned something tho lol. I have dont lots of compression tests before, but this was the first one whare I took the harness off. so if anyone is going to do one, make sure your distributor is disconected or that your leads are grounded.
Shafto is offline
