Old 07-28-2005, 08:38 PM   #1 (permalink)
appleyard777 is an unknown quantity at this point
DEAD!
alright well goin on the normal routine to get some gas ... come back out to the car starts up very sluggish though turned over a few times and kinda struggled and sputtered but started... i make it to the redlight then i rev it up to about 2k just to see if it would idle right and it just died... took about 2min to start the damn thing and it was veryyyy boggued down sounding when it started and struggle alot, pulled over in parking lot.. then it just wouldnt start after that... went and got a new battery, that didnt do a damn thing. Recently had new plug wires, coil, and distrubutor put on about a month ago. Any ideas guys?... maybe coil went out again, maybe alternator, possiblye fuel filter??
appleyard777 is offline
Old 07-28-2005, 10:17 PM   #2 (permalink)
Car: 1994 Acura Integra LS
Sounds like it mightbe out of timing.
Originally Posted by 9400rpms
lugnutRS is offline
Old 07-28-2005, 10:25 PM   #3 (permalink)
dammit i hope not.... got it replaced about 3 months ago
Old 07-28-2005, 10:41 PM   #4 (permalink)
fleming23's Avatar
Car: 97 Prelude
Mods: Header, High Flow Cat, AEM Intake, 18" ADR Spade Wheels, Infinity Reference Componet, Infinity 6x9 rear, Alpine Head Unit
fleming23 will become famous soon enough
sounds like a blown headgasket... Now it MAY NOT be your head gasket before someone says i'm a moron for suggesting that... BUT if you did indeed blow the gasket then your cylinder would slowly start leaking fluid into the block and it would start running like ass and once it finally can't burn the water and coolant anymore it will die and not start back... Just to see try pulling out your plugs and turn the motor over. If a whole shit load of water and stuff blows out the top, BINGO... if not, you wasted maybe 15 minutes.
1997 Prelude
fleming23 is offline
Old 07-28-2005, 11:38 PM   #5 (permalink)
Car: 1991 Acura Integra GS Sedan
G2IntegraGS will become famous soon enoughG2IntegraGS will become famous soon enough
yeah it wouldnt hurt to take off a spark plug just to check. You dont want to damage your engine anymore. What year teg is it?
G2IntegraGS is offline
Old 07-29-2005, 12:15 AM   #6 (permalink)
Car: 90 CRX, INTEGRA GSR 2000(stolen)
or to check to see if you have a blown headgasket i would recommend use an airhose and put it in where you add oil and unscrew your radiator cap and see if there are any air bubbles coming up in your radiator .
gsro11 is offline
Old 07-29-2005, 06:43 AM   #7 (permalink)
yeah well i might have to try that... its a 95 with a rebuilt motor.... 30,000 miles on a complete rebuild
Old 07-29-2005, 06:50 AM   #8 (permalink)
alright well fuck i just remembered something i checked my oil awhile back... and i thought it was kinda akward how it was more oil in it than before like someone had filled it up so im like wtf... didnt think much about it.... could this be anything??
Old 07-29-2005, 09:17 AM   #9 (permalink)
one more thing i might add... it had been idling really low lately like for the past few weeks... and at a stop it would kinda sputter really really low though almost couldnt hear it.. it did that not often but sometimes
Old 07-29-2005, 09:22 AM   #10 (permalink)
im thinking possibly fuel filter, and maybe clogged cat because it sounded really rough underneath my car when i tryed to start it like just really chopped up but i dunno for sure
Old 07-29-2005, 11:46 AM   #11 (permalink)
has the car always had a gas cap
gsro11 is offline
Old 07-29-2005, 12:10 PM   #12 (permalink)
yeah well as long as ive had it.. why so?
Old 07-29-2005, 01:18 PM   #13 (permalink)
because if water or moisture had gotten into the gas tank it would rust the tank and ruin the fuel pump causing it to studder and eventually go
gsro11 is offline
