Car: 92 Honda Civic B16(cx) H/B
Mods: J Spec B16A SiR, S 1 Tranny, Limited Edition GSR wheels, Ground Controls, Cold Air Intake, Apex-I N1 Exhaust,G2 short shifter,projector headlights,etc.
differences between usdm and jdm b18c1
i am buying a usdm b18c1 and i would like to know the difference of the specs of the jdm model and the usdm model thanks.
Basics
Car: 92' Civic CX H/B
Motor: J-Spec B16 SiR 1 (converted to OBD1)
Exhaust: Custom full 2.5 w/N1
Wheels: Limited Teg. GSR's
Sound: Clarion head unit, 2 12" Orion XTR's, Sony 1000 watt amp, Lighting Cap w/volt meter, Infinity Kappa front and rear, MTX Tweeters
previous cars:
89 CRX Si - Yellow
89 CRX Si - Red
92 Integra - Red (B18 Frankenstein motor)
90 B16 CRX Si - Black (R.I.P.) Never let friends drive your car!!!
jdm b18c1
hp: 176@7600
tq: 129 @6200
CR 10.6:1
tranny has a limited slip differential.
USDM
hp: 170
tq:124
no lsd.
CR: 10.0:1
there you go. thats the differences
-=AREX=-
I believe the JDM was 180PS, which translates to 176hp. I thought the LSD was optional in Japan, but maybe I'm wrong on that one.
Originally posted by White98LS I believe the JDM was 180PS, which translates to 176hp. I thought the LSD was optional in Japan, but maybe I'm wrong on that one.
See thats what I thought about the LSD. and yeah 180PS = 176HP
As for torque
JDM: 129lbs-ft@6200rpm
USDM: 124lbs-ft@6200rpm
And I believe the compression are different in the two as well, not sure though. :
Originally posted by Nguyen See thats what I thought about the LSD. and yeah 180PS = 176HP
As for torque
Yeah the compression is different as rufus`` mentioned. They have much higher octane gas so they can run higher compression without worrying about detonation. Bastards. On the other hand, they pay a lot more for gas....
Originally posted by White98LS Yeah the compression is different as rufus`` mentioned. They have much higher octane gas so they can run higher compression without worrying about detonation. Bastards. On the other hand, they pay a lot more for gas....
Yeah and I thought gas was freakin expensive already..hehe
