ecu, abs problem
my car failed inspection for 3 codes:
P1456 Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System)
P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
P0171 Fuel System Too Lean.
i was told that i needed the stock intake back on there to fix it. i got it, put it on and it did nothing. i then saw a hole in the charcoal canister. i patched it up and it was fine. but then it came back on.
i used the jumper trick this time after the CEL came back on today after 78 miles of being off. it said this
90 Evaporative Emission Control System leak detected in the fuel tank area.
i fixed the charcoal canister so it cant still that. what could it be?
also, ABS system threw an 11 - wheel senor (open/short to body ground/short to power) FR. what could i do to fix this?
