Electrical Issues. need help asap!!!!!
I drive a 92 integra with a B16A1 swap in it. Ive had no prior electrical problems besides cruise control.
I was working on my underglow, wiring it into the car and wiring it to the switch. i found a constant source about 6 inches behind the driver side knee bolster and T tapped onto it. when i went to hook it up the switch i might have shorted it on the bare metal knee bolster. and when i went to hook the wires up to the switch i couldnt get the continuity right at first (OFF turned the underglow on and ON turned the underglow off). so I might have thrown power to a ground source or ground to a constant source. None of the fuses in the car are blown and all the fuses under the hood are fine. 12 volts on all of them. checked them with a meter. nothing in the car works. no power at the key. nothing. no lights, no switches, no interior power what so ever. so i think it might be a fried relay or a fried main fuse. i need some advice on where to go from here. The wires never got hot and there was no pop or blown fuse. no melted wires either. Please help
