03-31-2006, 06:41 PM
#1 (permalink)
Car: 94 integra ls---95 civic
Mods: vanilaroma air freshener
enuf backpressure???
My piston rings just went on my g2 and the mechanic i took it to to get fixed said it was because the exhaust did not have enuf back pressure. I only had a cat back on it and it was a good one. I have headers, a high flow cat and full exhaust on my g3 and i dont want this to happen to that one. what is the deal? are exhausts bad for hondas? Mechanic said hondas are made to run with more back pressure than these so called "muscle cars"
03-31-2006, 06:43 PM
#2 (permalink)
Car: 1994 Honda Prelude SI
Sounds like BS to me, but I could be wrong.
1991 Acura Integra GS(Sold ) 1994 Prelude SI
FS: 1996 TL 15" wheels/tires.
03-31-2006, 07:01 PM
#3 (permalink)
Car: 99 Prelude Type SH, 83 RX7 GSL
You're not wrong. The mechanic is wrong, and should be punished for spouting misinformation that he should be knowledable of.
Why on earth would you want back pressure? Exhausts are designed to expel the exhaust gas, and back pressure prevents this, so what would be beneficial about preventing the exhaust from doing what it's supposed to do?
PFC USAR - Light Weight Vehicle Mechanic
83 RX7 GSL: LS1 and other go fast goodies
99 CMB Prelude Type-SH:
Type-s swapped, type-s front lip, type-s front strut bar, progress adjustable rear sway bar, jdm fogs, mugen exhaust, SRI, mugen coilovers, mugen thermopak, competition clutch(stage 3)/flywheel, hawk HP+ brake pads, CF hood/trunk... and more to come.
Autocross is for drivers.
Drag racing is for cars.
Prelude FAQ
03-31-2006, 10:36 PM
#4 (permalink)
Dark Samurai
Car: '98 Integra LS hatch
Mods: See website in sig.
Exactly. You want NO backpressure... and at any rate, low/no backpressure in no way could cause engine damage. Your mechanic is a dumbass.
http://www.freewebs.com/white98ls - don't forget to sign the guestbook!
03-31-2006, 10:53 PM
#5 (permalink)
This is all news to me. I thought backpressure is what creates a push-pull effect on the pulses of gas as they exit the exhaust. If having no backpressure was beneficial, then we would have 2" collectors, 2.5" piping, and 3" exhausts.
Ryan
04-01-2006, 02:31 AM
#6 (permalink)
Dark Samurai
Not that far fetched at all... I have a 2" collector, 2.25" cat, and 2.36" exhaust piping. You always want to either match or step up on the exhaust side.
Can't confuse backpressure with flow velocity. Any kind of backpressure means that exhaust gases are being trapped rather than scavenged out - not a good thing. Too big piping = low/no backpressure perhaps, but low flow velocity means the exhaust gases just kinda hang around rather than being smoothly and easily flowed out. Too small piping = high flow velocity, but too much exhaust being crammed into a small pipe means lots of backpressure. A properly sized pipe will be big enough to not cause backpressure, but small enough to enable a quick and smooth exit.
Think of your vacuum cleaner's attachment hose in reverse. If the hose was 1 foot in diameter, you'd get no suction and wouldn't be able to pick up hardly anything. If it was 1/4" in diameter, there would be a lot of suction (high flow velocity) but surely the motor inside the cleaner would be straining to pull in more air than can fit in that tiny hose (backpressure in a sense). At about a 1.5" diameter like most vacuum cleaners, it's big enough to match the capacity of the vacuum cleaner's motor, yet small enough to get the air speeding along quite quickly.
04-01-2006, 10:38 AM
#7 (permalink)
Would it benefit you to get a 2.25" collector?
Ryan
04-01-2006, 11:28 AM
#8 (permalink)
Dark Samurai
Probably, but the time/money involved (mainly retuning the thing) isn't worth it to me right now for just another hp or two.
04-01-2006, 01:22 PM
#9 (permalink)
thanks for the help, thats what i thought. white98ls are your hood hinges custom made?
04-01-2006, 02:07 PM
#10 (permalink)
Dark Samurai
Those bad boys are bone stock.
04-03-2006, 12:52 AM
#11 (permalink)
past the headers all u need is 3 feet of 2.25 pipe even with no cat
04-03-2006, 01:00 AM
#12 (permalink)
with out backpressure it fuckes some thing up forget what thou. 3 feet of pipe no biger the 2.25 ull have enuf backpressure and your valve wont cool so fast that thell bend
04-03-2006, 03:13 AM
#13 (permalink)
Dark Samurai
I've haven't heard that much bullshit is a long, long time.
04-03-2006, 04:09 PM
#14 (permalink)
Wow, i don't know what to say
04-03-2006, 04:47 PM
#15 (permalink)
Car: 1994 Integra
Mods: Built JDM ITR engine, need I say more?
