Originally posted by lowacura
I just bought a USDM type-r header, cat, and b-pipe, but still have my stock gs-r muffler... is the type-r piping better than the gs-r piping? the header and the cat any different too?? it should be better, right?
I'm not really sure if the USDM ITR B-pipe matches up to the USDM GSR axle back section. It might, I'm just not sure though.
And even if it does, you won't experience much if any gains since the ITR piping is 2 1/4" and the GSR piping is near 1 3/4" to 2 " in many sections. So you'll be going from a larger diameter pipe to a smaller one and will create turbulance at the flange.
The USDM ITR is one heavy MoFo as well and is a 4-2-1 cast exhaust manifold. It is not what ITR owners keep. We sell these lead weights and get the JDM 4-1 header for better weight advantage and performance gains. OR save a bit and get an even better designed header.
If you want a good quiet exhaust, then get the ITR B-pipe and axle back section.
Good luck,
A.
