Old 10-06-2004, 08:33 AM   #1 (permalink)
bamirza is an unknown quantity at this point
Handbrake left on for quarter mile
my dumbass brother took my integra for a spin through the residential streets with the handbrake on (its an automatic but was parked on an uphill.) anyway, just wondering if any damage can occur cuz of that.
bill
bamirza is offline
Old 10-06-2004, 11:44 AM   #2 (permalink)
Car: 94 Integra LS
Mods: 17" Exel Ennio rims
Curufin will become famous soon enoughCurufin will become famous soon enough
I think that the hand break works only on the rears, someone correct me if im wrong, so the only dmg that I can think of would be to your rear discs.... Also, it would not surprize me to know that your hand break would need to be tightened alot now... Check your rear disc breaks for heat dmg, scoring/etching, that sort of dmg...
Curufin is offline
Old 10-06-2004, 01:03 PM   #3 (permalink)
Dark Samurai
Car: '98 Integra LS hatch
Mods: See website in sig.
1/4 mile shouldn't hurt it too much. At that distance you probably just wore on the brake pads a little and the e-brake cable might need to be tightened a bit - they need to be adjusted periodically anyway. Really easy thing to do yourself, don't pay a dealer to do it. If you need to know how to do it, let me know. But as long as the e-brake still works and you don't feel pulsating when you use the brakes (warped rotors) I'd say you're fine. Now go bitch-slap your brother. :clap
White98LS is offline
Old 10-06-2004, 01:06 PM   #4 (permalink)
Car: 04 Acura TL
4DGSR will become famous soon enough
X2 :clap
4DGSR is offline
Old 10-06-2004, 01:51 PM   #5 (permalink)
Car: 94 Integra LS
Yeah, and hand your brother a good ass-whoopin' for being a fucking idiot....
Curufin is offline
Old 10-06-2004, 05:23 PM   #6 (permalink)
subaruwrx18's Avatar
Car: 04 Scuby WRX
Mods: turbo back and up pipe. rims/tires/springs coming soon!!!
subaruwrx18 In the stratuspheresubaruwrx18 In the stratuspheresubaruwrx18 In the stratuspheresubaruwrx18 In the stratuspheresubaruwrx18 In the stratuspheresubaruwrx18 In the stratuspheresubaruwrx18 In the stratuspheresubaruwrx18 In the stratuspheresubaruwrx18 In the stratuspheresubaruwrx18 In the stratuspheresubaruwrx18 In the stratusphere
bill
then use his teeth to tighten up ur ebrake cable instead of a wrench
Anthony
subaruwrx18 is offline
Old 10-06-2004, 06:56 PM   #7 (permalink)
jon
jon's Avatar
hel yeah
silence is golden
but duct tape is silver
jon is offline
Old 10-07-2004, 06:25 PM   #8 (permalink)
playahwitgame is an unknown quantity at this point
how do u adjust the handbrake??????
playahwitgame is offline
Old 10-07-2004, 06:57 PM   #9 (permalink)
Mr GSR's Avatar
Car: 1995 Integra GSR BG-33P
Under you arm rest console (you have to take it out) there is a weird looking device with two nuts at the end of two cables. Turn them and it will tighten up your e-brake. I don't remember which way tightens and which loosens, but you can figure it out from there.
Mr GSR is offline
Old 10-07-2004, 08:26 PM   #10 (permalink)
Dark Samurai
To figure out how much to tighten, you'll need to do this:
1. Jack up the rear of the car, both sides.
2. Spin each wheel with the e-brake off, to observe how much drag there is naturally, with no brakes.
3. Pull e-brake lever up ONE click/ratchet.
4. Tighten e-brake cable nut (described above) until there is a slight drag.
5. Fully release e-brake lever and spin wheel to make sure there is no drag from the brake.
6. Lower the car back down and reinstall the center console.
To get the console off, with a flathead screwdriver pop off the small panel in the middle of the console (the plastic which surrounds your hand when you grab the handle in the down position). Underneath are two large Phillips head screws. Unfasten those and the black Phillips screw on each side of the console box (near the back of the box on the outside).
Old 10-07-2004, 08:31 PM   #11 (permalink)
good information.. i never thought about that.
viet_83 is offline
Old 10-08-2004, 01:28 AM   #12 (permalink)
is there a certain amount u cant keep tightening it?
Old 10-08-2004, 02:13 AM   #13 (permalink)
Dark Samurai
Well yeah I mean you can't tighten it infinitely, but there's quite a bit of room to play with.
