I have a 95. was coming home stopped at a light idled fine press the gas and bogged down. (Almost stalled.) let off and pressed again was fine. about 3-4 hrs later drove again did the same thing stopped at a light pressed the gas competly died. AND NOW WONT START... looked at timing belts in good shape took disributor cap apart looks okay. I believe it's pumping fuel. Not quit sure. Spark plugs are dry. changing the fuel filter tomorrow.. When i turn the key Check engine light stays lite, was never on before and the ABS light stays on. It's a auto Trans. and when you press the break theres a clicking noise by the shifter??? I believe thats from the soliod that lets you put the car into gear! Would that cause the car not to run? OR Would that cuz the ABS light to be on.. There not flashing.. Please help with any idea on what it could be to make it just die!!! no real warning!!!! Thanks guys
could be something electrical, check the alternator, or you could have a dead cell in the battery,
get the code checked out to see what is says then check back here. or it may solve the problem just knowing what its on for
