Same here. Mine is the Skunk 2 N1 and "Ting's" slightly into 5th.
But, just when I shift aggressively into 5th gear. Sometimes you can tweak it a bit and push the pipe away from the shifter a bit,,, And other times, you just have to live with it. Regard;ess of if it was made for your car.
Good luck,
A.
