I recently bought a Acura Integra supposedly a GSR the cars not with me atm but i have a picture of the engine.
I wondering if anyone can id the engine for me i was told its a GSR but i think it could be a itr where can i find the engine code on the engine anyway?
How will the rust affect the performance? should i get it replaced soon?
I woulnt worry about it so much you will know when you need to replace it when your engien sounds like a lawnmower due to an exhaust leak from a crak or hole in it. Unless you have the money id go ahead and replace it just cause it would bother me. DC sports makes good headers for honda
I'm thinking it's a GSR with a red valve cover on it. Look at the intake manifold, it rises up from the head to the throttle body area. I thought the R's mani was more straight.
the gsr manifold comes from under. you would be able to see the runners clearly if that was a gsr manifold. also, you'd see the intake pipe take a dip down right before the tb.
it looks like my head and i have a b16 head.
excuse the dirtyness..
Originally Posted by flyracerx
looks like a b16 to me.
Your right.... I haven't looked at my engine in a bit. The first one does look like mine and the second looks more like yours.
It looks like a b16 head. I think the GSR water outlet (upper radiator hose) is in the front of the head and the b16 is in back part...Also where is your GSR strut bar?
Car: 2004 Rsx Type S,1998 Twin Turbo Supra,Fiances car 2003 Evo 8
Mods: Ask to many to bother listing....Plus theres not enough room
The code should be on the block under the head down on the left side of the block about half way down. So if your standing in front of the car....looking at the motor......look mid way down on the left...you should see the code clearly.......
Mods: 16" Volks, Stage-2 Six Puck Clutch w/HD Pressure Plate, Lightened Flywheel, DC Sports Short Shifter
too many variables to identify the engine from a pic, the only way to tell is the block's stamp code. also the head should have "p72" stamped on it near the distributor if its matched to a GSR block (if it is a GSR block).
my hunch is that its a b16. (a common and cheaper replacement after a blown or stolen motor.)
and a side note: the stock exhaust manifold is always rusty in most cars, its cast iron so it will take a very long time before the rust causes any leaks or cracks.
