which ends were covered in oil? If it is the top where the spark plug wire attaches then most likely you just need to replace the valve cover o rings. If it is the electrode end in the combustion chamber it sounds like your piston rings are going going gone and you could do a compression test to help you find out. Good luck
Halo 2 Xboxlive id= Scotty0
