Old 05-20-2002, 09:12 AM   #1 (permalink)
Car: 94' Integra LS
Mods: Intake
Beeluv is an unknown quantity at this point
Angry HELP!! No Detonation!!!
Help pls! I did a basic tune-up this weekend and all I did was change plugs, wires, cap, and rotor. After putting everything on my car will not start. It will turn over but it will not start. I checked all parts..and even re-installed the old parts to see if it would run..but to no avail. The car was running before installing the new parts. I inspected the new parts..and see nothing physically wrong. I smelled gas on the plugs..so I believe they are getting fuel. A friend put a volt-meter on the plug wire and we attempted to start it..and the volt-meter said there was no current going thru the wire. Anyone with any ideas as what to check next....would be greatly appreciated. I wanna get back in my TEG as soon as possible!!!!!
Beeluv is offline
Old 05-20-2002, 09:23 AM   #2 (permalink)
Car: 2000 VSM Honda Civic EX 5sp Coupe
Mods: Under construction...
00CivicVTEC is on a distinguished road
First off, detonation is when the air/fuel mixture in the cylinders ignite before the actual sparking of the plug....also called pre-combustion...that is BAD, you do not want that!
Just had to clear that up for you
So, you are not getting a spark at all? Did you gap the plugs correctly? Did you make sure the plug wires are secure on the dist. and the spark plugs? Did you accidentally disconnect the coilpack? Did you install the RIGHT parts?
It is just something simple, I'm sure...
2000 Civic EX Coupe 5-speed
00CivicVTEC is offline
Old 05-20-2002, 09:28 AM   #3 (permalink)
Car: 94' Integra LS
Mods: Intake
Thanks for the clarification! Well I checked everything you said and checked it twice. The gap is good...wires and boots snapped tight. Another buddy said that it might be the ignition coil???? The thing is that the car was running just fine before I touched anything.
Beeluv is offline
Old 05-20-2002, 09:44 AM   #4 (permalink)
I used to do "no-start" diagnostics all the time, so I hope I can help you out...
Goto the autostore and get a spark tester...if there is no spark, then most likely you have a bad coil. If you DO have a spark, the most common thing is a dirty fuel filter or bad fuel pump. To test a fuel pump, disconnect the fuel line from the fuel rail and then crank the car, if the fuel shoots out from the fuel line, then you have fuel pressure...
It really does sound like a coil issue thou, call up your Honda dealer and give me the part#, and price, and I will see if I can get it cheaper (only take me a couple of minutes to check).
Also, make sure all contact points on the rotor and dist. cap are clean.
Also, we had integras come in to work all the time for "no starts" with a bad dist. to blame....they seem to be really bad about that...better hope it isn't that, because that is not a cheap repair.
If what I told you does not help you fix your problem, you will have to take it to your local autoshop and get a diagnostics done where they hook it up to a computer.
Old 05-20-2002, 09:53 AM   #5 (permalink)
Car: 94' Integra LS
Mods: Intake
I do not have a spark. We checked to see if I could get a spark. I think I will check the ign. coil? What do you think?
Beeluv is offline
Old 05-20-2002, 10:18 AM   #6 (permalink)
Yes, it sounds like a coil or bad distributor. The only real way to tell is to get it hooked up to a diagnostics computer.
Like I said, call up the Honda dealer and get a part number and price for your coil, and post it up...they usually aren't that expensive.
Old 05-20-2002, 11:57 AM   #7 (permalink)
Car: 94' Integra LS
Mods: Intake
Thanks for you input. I will check into it.
Beeluv is offline
Old 05-20-2002, 02:41 PM   #8 (permalink)
Sloth is an unknown quantity at this point
do you have a CEL? (check engine light.)
Sloth is offline
Old 05-20-2002, 07:34 PM   #9 (permalink)
SlapSmak is an unknown quantity at this point
the coil for a vtec teg is 192$, (from experience), i dont know what the LS coil runs.
2000-DC2R PY 00319
JDM DC 4-1 SS
SMS Custom Race Cat
ShortRam
Goodridge SS Lines motul 600
Hawk HP+ pads
B&M shift kit
SlapSmak is offline
Old 05-20-2002, 07:47 PM   #10 (permalink)
I can usually get about 50-75% off what the dealer charges on some parts....I can get every part cheaper than the dealer charges gaurenteed. I just need the part number to look up a price....but if it cost that much, I would just personally put a MSD "power tower" ($10) on the dist. cap, and run a Blaster SS coil ($35-40). Oh, and don't forget to add the ballast resistor you are suppost to add, or the coil will fry, your car will stall one day in the middle of the road, and your catalyst will be completly fried from running too ruch....trust me on this....it happened to me!
Old 09-10-2002, 08:51 AM   #11 (permalink)
mojo is an unknown quantity at this point
i have the exact same problem with my JDM vti teg
i was thinking along the same lines
coil is coming in at 33 dollars
mojo is offline
Old 09-10-2002, 11:04 AM   #12 (permalink)
Car: 95 gs-r
RippinTheVtec has much to be proud ofRippinTheVtec has much to be proud ofRippinTheVtec has much to be proud ofRippinTheVtec has much to be proud ofRippinTheVtec has much to be proud ofRippinTheVtec has much to be proud ofRippinTheVtec has much to be proud ofRippinTheVtec has much to be proud ofRippinTheVtec has much to be proud ofRippinTheVtec has much to be proud of
did you damage the coil when taking off the rotor? I know they are a bitch to ge off some times.
did you make sure the wires are in the right order on the cap
1-3-4-2 not sure which way it goes or where it starts but if i had my car i could go look and tell ya but it's in the body shop.
2.0 All-Motor Gs-r
1.5T CRX
97 F3i :eek
03' V6 Accord
(This is what powered by Honda means)
RippinTheVtec is offline
Old 09-10-2002, 11:13 AM   #13 (permalink)
WOT
WOT is an unknown quantity at this point
igniter got damaged when you fucked with cap and rotor...did you use a Helms manual or were you fishing in the dark and guessing?
WOT is offline
Old 09-10-2002, 12:50 PM   #14 (permalink)
Car: 94' Integra LS
Mods: Intake
In my situation I forgot to disconnect the neg. battery terminal...which in turn shorted out the Ign. coil.
Beeluv is offline
Old 09-10-2002, 02:33 PM   #15 (permalink)
Car: POLICE OFFICER
nov0798 is an unknown quantity at this point
you most likely have a bad igniter. if you have a manual you do not need to hook up to any special computers, etc. simply do the recommended checks and you should be ok.
http://syntheticoil.netfirms.com
nov0798 is offline
