Originally posted by azian21485
i could just check for the b18c5 engraved..but exactly where do i look for it? also, is there a way of telling if he installed the type r lsd? (the lsd should come with the tranny if he took the tranny from the R correct?)
Well youre on the right track...a red valve cover doesnt really mean anything however and I'm glad you realize that. The location of the engine code is directly to the left of the header about half way down the block....it's very hard to miss. Also, if its a JDM Type R swap, it wont have the "5" at the end...only B18C. Lastly if they took the tranny from the Type R, then it should have the LSD, unless taken out. The easiest way to find out if the car is LSD equipped is to do a burnout...if there are 2 equal length tire marks, then it's LSD equipped...if not the LSD is not there. Good luck...
