Old 04-07-2004, 12:08 AM   #1 (permalink)
wildest5 is an unknown quantity at this point
type-r I have a 95 integra ls and it is pretty built
I have a 95 integra ls and it is pretty built and i am running without a cat on my exhaust and it has been about a year without the cat and i am noticing a conciderable amount of oil being burned I will go through about a quart every two weeks. i was told by someone that it might be a headgasket but for some reason that doesn't seem right to me. so if there is anyone out there that can give me a definite of what it could be that would be cool.
thanks.
wildest5 is offline
Old 04-07-2004, 12:11 AM   #2 (permalink)
-Todd-'s Avatar
Car: 1992 Civic vx
-Todd- is a rep whore-Todd- is a rep whore-Todd- is a rep whore-Todd- is a rep whore-Todd- is a rep whore-Todd- is a rep whore-Todd- is a rep whore-Todd- is a rep whore-Todd- is a rep whore-Todd- is a rep whore-Todd- is a rep whore
What all is done to it?
-Todd- is offline
Old 04-07-2004, 01:00 AM   #3 (permalink)
type-r intake header exhaust crower spec 3 cams stage 4
intake header exhaust crower spec 3 cams stage 4 port polish shave titanium valves springs retainers fuel pressure regulator new intake manifold safc controller oil psi guage and no catalytic converter
wildest5 is offline
Old 04-07-2004, 01:19 AM   #4 (permalink)
just wondering
and if anybody is wondering i run a 14.5 or so. also should i turbo it ir install integra type r pistons which are .025 oversized. what do you think will give me more hp or better track times.
wildest5 is offline
Old 04-07-2004, 01:23 AM   #5 (permalink)
Putting a turbocharger with those cams is not a good idea nor is increasing the compression on the turbo. You can increase the compression with your current setup and tuning it would give you more horsepower i.e. better track times . If you want better track times, an aftermarket clutch and flywheel and drag radials would be nice.
IntegraTypeRice is offline
Old 04-07-2004, 01:38 AM   #6 (permalink)
type-r what do you mean?
you said not to turbo charge it ok. but what about the pistons is that a bad idea also? my goal is to get into the mid 12's and i don't know if that is going to happen if there is a safe (expensive) way please do tell i would like to know.
wildest5 is offline
Old 04-07-2004, 01:49 AM   #7 (permalink)
Run the stock cams with a t3/t4e turbo. You need internal work done to run boost levels that would net 12 second 1/4 mile times.
Old 04-07-2004, 02:10 AM   #8 (permalink)
Dark Samurai
Car: '98 Integra LS hatch
Mods: See website in sig.
Yeah it's gonna take a LOT to get to 12's all-motor non-VTEC. It could be done, but it would be a ton of money.
Pistons would get you a nice gain in power all around, but you'd still probably be in the 14's somewhere. But if you could use a rebuild anyway, definitely not a bad way to go.
White98LS is offline
Old 04-07-2004, 07:54 AM   #9 (permalink)
PM-Performance's Avatar
PM-Performance is a splendid one to beholdPM-Performance is a splendid one to beholdPM-Performance is a splendid one to beholdPM-Performance is a splendid one to beholdPM-Performance is a splendid one to beholdPM-Performance is a splendid one to behold
not necessarily. i know plenty of people going 12's on stock LS motors in tegs on low boost on street tires.
FORMERLY ITR206
07 Solar Orange 350Z
91 Supra Turbo Targa-
1JZGTE 508WHP and 501tq SOLD
06 Pathfinder
PM-Performance is offline
Old 04-07-2004, 11:30 AM   #10 (permalink)
type-r what about my oil problem
i still need help with my oil problem because if it's hurting my engine i don't want to keep driving on it until it's fixed. thanks
wildest5 is offline
Old 04-07-2004, 03:12 PM   #11 (permalink)
Wow, I'm pretty impressed with that. Do you recall what psi levels they were running?
Old 04-07-2004, 03:50 PM   #12 (permalink)
Mods: 4door Teg- 13.8 ls/vtec
You have a built motor and now its burning up oil? BUILT, as in only the HEAD? That aint built
Looks like you need to up the compression with a head package like that. Crower 3's in a LS is just overkill....you can make more power with just a nicely tuned LS.
If I were you Id build my car according to how you modded your head. Up the compression and get the bottom end tuned according to your desire
______________________
94' integra sedan SOLD
03' Yamaha R1 ltd. Ed.
02' BMW 330 Ci
02' Suzuki GsxR
JAYMAN320 is offline
Old 04-07-2004, 10:31 PM   #13 (permalink)
i am running at about 75 psi at 3,000 rpm i think that is a little high. i know that i have alot of work done but i don't think i should be blowing as much oil as i am
wildest5 is offline
Old 04-07-2004, 10:34 PM   #14 (permalink)
Dark Samurai
huhWHA???!
Old 04-07-2004, 10:48 PM   #15 (permalink)
IntegraXTR's Avatar
75?!?!?!?!
errrrrrr
typo? haha that's like 5 bar
ENDLESS GARAGE : ::custom fabrication::dyno tuning::service & maintanance::
www.myspace.com/integraxtr
IntegraXTR is offline
» Network Links
