i am getting a cell code for intake air temp sensor (failure?) my mechanic pulled the code from it yesterday, and cleared it, and said that it ran fine after. but now my car putters every once and a while, same as it did when it came up with the CEL. so if the CEL code was for that sensor, i should probably replace it right? now, has anyone here ever done it? is it easy enough for a novice such as myself? (to do in the freezing cold) :P
or should i just let my mechanic do it? and around how much would it cost to buy a replacement?
if you want to read about how it happened see post:
never thought it would happen to me!
thanks
