Closed Thread
Old 04-20-2003, 12:39 AM   #1 (permalink)
randyman's Avatar
Car: 94 acura integra
randyman is an unknown quantity at this point
Integra Facts and answers to FAQ's...
This sticky will try to encompass frequently asked questions pertaining to performance and general information about the Acura Integra.
If you want to add to it, PM me. If you think something should be added PM a moderator.
DISCLAIMER:
If I paraphrase from any of your postings, feel good that you helped less experienced learn more.
I always attempt to credit the origional authors so please don't be offended if your information is posted with missed credit. If you have a problem then please contact me to resolve any matters. Otherwise just as above, your information is helping others learn more of what they need to know to further support the Import Performance community.
Following are important links:
Can I put a 98-01 bumper on my 94-97 Integra?
How to install JDM mirrors Gen 3
The Weight Reduction List By White98LS and DXE
Power was disconnected from my radio now i need the code?
Decoding B series motors
Honda OBD1 ECU pinout
Differences between Integra's
TPS troubleshooting
THE Ls/Vtec post "Frankenstein motor's"
I/H&E discussion with the Type-R boys N/A !!!
The GREAT Header test
Intake showdown
15 exhaust sound clips
94-01 fuel filter R&R
Axle replacement
Hybrid swaps
ITR#231 talks Brakes; rotors, pads and calipers...
Spoon B series motor specs
DIY-- Oil catch Can, How To.
Cylinder head removal.
Walbro fuel pump install.
JDM ITR "Non-HID" headlamp pinouts.
JDM ITR "HID" headlamp pinouts.
LS/Vtec Stuff
heads
Whats needed for LS/Vtec?
Stay tuned,,, more to come!!!
1994 Acura Integra B20/VTEC (SOLD)
00 Mercedes Benz M-CLass
02 Porsche 911 Turbo
01 Mitsubishi Eclipse
...Yes, I'm an arms dealer!
randyman is offline
Old 04-20-2003, 12:41 AM   #2 (permalink)
randyman's Avatar
We'll start with ECU's
PG6 : 88-89 Integra (all makes)
PM5 : 88-91 Civic/CRX DX
PM6 : 88-91 Civic/CRX SOHC Si
PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
PM8 : 88-91 CRX HF
PR2 : 89-91 ZC (Euro)
PR3 : 89-91 JDM B16A EF8/9
PR3 -J00 or J51 : 92 JDM Integra B16A EF8/9
PW0 : 89-91 JDM B16A EF8/9 DA6-XSi
PR4 : 90-91 Integra LS/GS
PS9 : 88-91 4 door Civic EX Auto
P05 : 92-95 OBD-1 Civic CX
P06 : 92-95 OBD-1 Civic DX
P07 : 92-95 OBD-1 Civic VX
P08 : 92-95 OBD-1 Civic D15 JDM
P0A : 94-95 OBD-1 Accord EX
P13 : 93-95 OBD-1 Prelude Vtec
P14 : 93-95 OBD-1 Prelude Si (non Vtec)
P27 : 92-95 OBD-1 EG JDM Civic 1600 sohc
P28 : 92-95 OBD-1 Civic Si/Ex
P30 : 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P54-G31 : 1997 Honda Accord 1.8 LS
P61 : 92-93 OBD-1 Integra GSR
P72 : 94-95 OBD-1 Integra GSR
P72 : 96-99 OBD-2a Integra GSR
P72 : 00-01 OBD-2b Integra GSR
P73 : 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75: 92-95 OBD-1 Integra LS/GS
P75 : 96-99 OBD-2a Integra LS/GS
P75 : 00-01 OBD2b Integra LS/GS
P2N : 96+ OBD-2 Civic HX Coupe
P2P : 96+ OBD-2 Civic EX Coupe
P2E : 96+ OBD-2 Civic DX Coupe
P2M : 96+ OBD-2 NZ Civic SOHC VTEC
P2T : 99+ OBD-? Civic Si Coupe
P5P : 97-00 OBD-2 Prelude Type-S (JDM ECU)
PBA : 97+ US Acura 1.6EL
PCT : 98+ JDM ITR / CTR
PCX : 99+ OBD-? S2000
Thanks to "probinu"
randyman is offline
Old 04-20-2003, 12:43 AM   #3 (permalink)
randyman's Avatar
ECU codes:
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
63 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
Credit to Drumsy (blzn_saddles), Thanks for the information I'm sure everyone appreciates it.
randyman is offline
Old 04-20-2003, 12:46 AM   #4 (permalink)
randyman's Avatar
Integra colorcodes
taken from team integra... (they need some credit. morningz used to be on here i think...)
Code Color
B-74P Adriatic Blue Pearl
B-90P Supersonic Blue Pearl
G-82P Cypress Green Pearl
NH-0 Championship White
NH-583M Vouge Silver Metallic
NH-538M New Vouge Silver Metallic
NH-592P Flamenco Black Pearl
Y-56 Phoenix Yellow
B-92P NIGHTHAWK BLACK PEARL
NH-592P (CAN) Starlight Black Pearl
NH-597M Citrus Silver Metallic
R-505p Cyan Red Pearl
R-81 Milano Red
B-97M Voltage Blue Metallic Clearcoat
G-95P Clover Green Pearl Clearcoat
BG-33P Paradise Blue-green Pearl
G-71P Isle Green Pearl
NH-503P Granada Black Pearl Pearl
YR-506M Desert Mist Metallic
RP-24P Stealth Grey Pearl
NH-538 Frost White
R-72P Torino Red Pearl
R-93P Matador Red Pearl
NH-575M Thunder Gray Metallic
Thanks to "rufus``".
randyman is offline
Old 05-02-2005, 10:22 PM   #5 (permalink)
CRVTEC0WNZJ00's Avatar
Car: 1993 Civic Si
Mods: Too many
B-Series Transmission Specifications
B-SERIES TRANSMISSION SPECS AND CODES
About SEAFOAM
SEAFOAM AND THE LIKE
2006 Laguna Blue Pearl S2000.
CRVTEC0WNZJ00 is offline
Closed Thread
