all you have to do is take your stock cluster apart (the white backing and green film). also, don't forget there's 3 long screws that you have to take off as well that are holding the cluster together.
undo the bulbs, and whatever you want to switch on over (ie seat belt, door ajar, etc)..
then just swap it over and plug the cluster into your car.
tada
on a side note, the 97 spec and the 98 specs are diff. the abs and srs lights are connected with a separate harness that plugs into the back of the cluster.
