Hi i searched and couldn't a direct answer... I heard that although the JDM ITR header has a 2.5 inch collector, it can restrict flow when you get past 200 whp. One reason I heard is that the welds are on the inside of the collector as opposed to outside, making it not a true 2.5. Is that what restricts it? Thanks
1995 Black Integra GS-R
Engine: advanced timing, Generic CAI w K&N Filter
Suspension: stock
Whl/brk/tr: Kumho Ecsta ASX(front), MasterCraft Avenger(rear)
Appearance: All Red LED TailLights, blk TypeR ShftKnb, OEM single sided cf hood
Audio: Alpine 9843 CD/MP3 Receiver, Polk db6500 Components(front), Polk db650 Coaxials(rear)
Security:
I dont know about restricting at 200whp but it gave my buddys b16 a little bit more
Restrictive, no. Restrictive compared to a suctom header, maybe. It all depends on your definaition.
Comparing it to any other mass produced header out there though its probably your best bang for the buck. It has an OD of 2.5" so the ID is a lot smaller. But still larger than a 2" OD collector, which also means the ID of the 2" header is smaller.
When you are making that much power, its really dependent on header design and layout, not the welds itself. Of course a bad weld is not a good weld, but its probably one of the less things on your mind.
I currently have the jdm dc2 header on my car. 4-1 tubular with a 2.5 collector. Great header. The butt dyno loved it. It responded very well with the mods i had at the time which were the full list of boltons you know header intake exhaust manifold cat etc. Speaking with some experienced tuners and engine builders i am under the impression that my engine will now choke with the header. Engine has more now than just bolt ons. not exactly sure why it would "choke" on the dyno with this particular header. My estimated goals for the engine are the 200whp range and up. My header is dented underneath due to some "spirited driving in ny" aka pot holes. Looking into the rmf narrow version.
The itr header is a good one dont let anybody tell you its restrictive or anything like that. There are plenty of 200whp cars that run that header and do just fine.
Originally Posted by d336
Is the DC JDM header have a true 2.5?
they answered no. its outside diameter is 2.5 but the inside is a little smaller
When they say 2.5" collector, they mean OD, not inside. Thats the general rule for every header. Unless they specify it being an ID measurement, you can almost bet its an OD measurement.
Many people have modified the JDM header into a long tube header. It has been done. But by that time, I'd probably just shell out the money for a long tube header.
