Old 12-14-2002, 03:57 AM   #1 (permalink)
randyman's Avatar
Car: 94 acura integra
randyman is an unknown quantity at this point
JDM ITR "Non-HID" headlight pin-outs...
This is just a "rough" diagram on how to figure out which pin goes to which certain bulb. Get some "Slide Connect Female" connectors (4 on each housing), color coded wires, and crimping tool. Crimp the wires to the female connectors. Once that's done, just slide each connector to the corresponding pin to power up the headlamp.
Left Headlamps
Right Headlamps
That should be it. Just plug in the 9006 bulb and its connector, like you would for the USDM headlamps. The same goes for the corner (turn signal) lamps. The fog light can either be powered by using a fog light wiring kit, or by splicing it to the 9006 wires. Make sure to replace the fuse for the 9006's (I used 30 amps). Otherwise, the stock fuse will keep blowing up everytime you turn your lights on.
Note: 9005 bulbs must be swapped out for H1 bulbs. Use H3 bulbs for the fog lights.
And that, as they say, is that.
1994 Acura Integra B20/VTEC (SOLD)
00 Mercedes Benz M-CLass
02 Porsche 911 Turbo
01 Mitsubishi Eclipse
...Yes, I'm an arms dealer!
randyman is offline
Old 12-29-2002, 04:04 PM   #2 (permalink)
Car: 99 Integra GSR
ekjdmr is an unknown quantity at this point
what kind of bulb do you use for the city light?
99 Integra GSR FBP
Nuespeed Springs
DC Short Ram Intake
ekjdmr is offline
Old 12-29-2002, 09:59 PM   #3 (permalink)
randyman's Avatar
the stock one from the USDM corner lamp (the little one, obviously). i believe it's 194.
randyman is offline
Old 12-30-2002, 11:21 AM   #4 (permalink)
Car: 99 Integra GSR
oh duh!!! thanks alot!!
99 Integra GSR FBP
Nuespeed Springs
DC Short Ram Intake
ekjdmr is offline
Old 03-30-2003, 11:30 PM   #5 (permalink)
Moe
Moe's Avatar
Car: 2001 Acura Integra
Mods: JDM front End,lowered,short shifter,AEM c/a intake
Moe Needs to go outside once in awhileMoe Needs to go outside once in awhileMoe Needs to go outside once in awhileMoe Needs to go outside once in awhileMoe Needs to go outside once in awhileMoe Needs to go outside once in awhileMoe Needs to go outside once in awhileMoe Needs to go outside once in awhileMoe Needs to go outside once in awhileMoe Needs to go outside once in awhileMoe Needs to go outside once in awhile
wha!?
which ones are the 9005's, another question these bulbs will fit right in perfectly??
Moe is offline
Old 03-31-2003, 07:29 PM   #6 (permalink)
randyman's Avatar
Re: wha!?
the 9005's are ur stock high beams. yes, the bulbs that i mentioned will fit in with no problems.
randyman is offline
