i have a rough problem that iv been trying for 2 years to fix now.
I have a 91 Acura Integra RS B18A1, non Vtech.
The main problem- Randomly dies like its not getting any gas...pedal down RPM's drop lower.
1. it IS getting gas to the injectors
2. iv changed out the fuel pump&sock, as well as cleaned out the gas tank.
ran good for 2 miles then same thing.
3. it IS in time, and the battery IS being charged.
4. the only other thing i can think of is "Overheating"....but temp gague says otherwise(with a new synsor)...stays in the middle.
5. when this problem randomly occurs the oil light comes on and a few sec's later the check engine light...
6. it will start fine after letting it set for a few, but as it runs the problems slowly creaps up and you can tell whats about to happen.
anyone have any ideas?
