Old 04-05-2004, 01:12 PM   #1 (permalink)
philtopspeed1 is an unknown quantity at this point
Looking to get a little more Top end power in my 96 gsr?
Hey guys I have a 96 gsr with cai,4-2-1 header,hi flow cat,stock exhaust,stage 1 clutchmaster clutch,and a fpr.I love my low and mid range power but I'm lacking top end.I'm asking what I can do to get a little more top end power without hurting the low and mid range that much.thanks for any advice you can give me.
philtopspeed1 is offline
Old 04-05-2004, 02:02 PM   #2 (permalink)
Car: 1996 Acura Integra GSR
fathead will become famous soon enoughfathead will become famous soon enough
What can you spend? More info would probably yield more responds.
fathead is offline
Old 04-05-2004, 03:04 PM   #3 (permalink)
Car: 2k dc2
sassage has a spectacular aura aboutsassage has a spectacular aura about
really, its almost one or the other....so you're basically gonna have to choose if you want top end or low end....and you need more info, decide what you want then choose your parts...your setup now is for midrange basically so it doesnt promote top end breathing....anyhow i would ditch the CAI and get a short ram, or just make your owm with some 3 inch plumbing and a big k&n, it will help your car breathe more at the top end...
"Loving the best, hating the Rest"
--Carl the Cat
sassage is offline
Old 04-05-2004, 03:50 PM   #4 (permalink)
Car: 1995 Acura Integra GSR
Mods: *See the sig*
*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere
id say get an exhaust
*1995 Acura Integra GSR* ***STOLEN 7/2/07***
Black On Black, 98+ Front Bumper w/ ITR Lip, Timing Advance, JDM P73 ITR Pistons, AEM CIA, Port & Polished IM w/ Hondata Gasket
DC Sports 4-2-1 Header, Random Tech Cat, Apexi N1 Cat-Back, ACT Street Clutch, B&M Short Shifter, Spoon Knob
Eibach Sportlines, Tokico Blues, Skunk2 Camber Kit, Powerslot Rotors, Hawk Pads, New OEM Calipers, Earls Stainless Steel Brake Lines
172hp @ 7750rpm
Thanks to xturbo420x for the sig!
*Vtec@8000RPM* is offline
Old 04-05-2004, 04:25 PM   #5 (permalink)
Dark Wind
Snoopy's Avatar
Car: something with wheels
Mods: whole lot of nothing
get some cams
Snoopy is offline
Old 04-05-2004, 04:47 PM   #6 (permalink)
Cypher Wave
Transparent's Avatar
Car: I dont own a car
Mods: fuck off
cams should help you out
I NEED A NEW
MOTHER FUCKING
SIGNATURE!!!!11
Transparent is offline
Old 04-05-2004, 06:17 PM   #7 (permalink)
GunMetal Member
Car: 94' Integra
KruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a life
some good cams, ITR would do
KruciaL7integra is offline
Old 04-05-2004, 07:31 PM   #8 (permalink)
Car: 2005 Audi A6/'04 R6
Mods: Nikko Slip-on, Zero Gravity windscreen.(R6)
gsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant future
Cams is the answer, either ITR or skunk2 stage 1 cams would do you good. Since you don't want the power to high up in the rpm range.
gsrteg is offline
Old 04-05-2004, 08:01 PM   #9 (permalink)
Car: 1994 Integra LS
jkdjoefzr is on a distinguished road
ITR cams and an ECU upgrade
Horsepower Junkie
jkdjoefzr is offline
Old 04-05-2004, 08:21 PM   #10 (permalink)
Girl is on a distinguished road
Exhaust will help a bit. I think you should get that before cams, cuz it's basically restricting everything else.
Girl is offline
Old 04-05-2004, 08:43 PM   #11 (permalink)
Haha! Redo your motor! Build that sucker up!
Seriously though, how much more do you want in the high ends? With a custom full exhaust setup from Hytech or SMSP, you don't have to sacrafice low end for top end. You get both.
Here is an example of the Hytech Header VS Comptech Race Header:
So you see, if you're serious about power gains, get something worth your every penny. It sure won't gut your low end for high end. No sacrafices here.
female four is offline
Old 04-05-2004, 11:18 PM   #12 (permalink)
It better be worth every penny, since you'll have to pay every penny you have... A Hytech header is around $1300.
Girl is offline
Old 04-05-2004, 11:27 PM   #13 (permalink)
Get ITR cams, skunk2 intake manifold, and convert the car to run a chipped p28 to increase your top end without sacrificing mid-range. ITR cams have better mid-range than the skunk2 stage 1 cams.
IntegraTypeRice is offline
Old 04-05-2004, 11:28 PM   #14 (permalink)
The dyno speaks for itself. The HP and torque numbers own every other header it was tested against. Plus I personally know people with these exhaust. Not only do they do their job, but are quality built as well.
Old 04-06-2004, 01:06 AM   #15 (permalink)
Mods: 4door Teg- 13.8 ls/vtec
How much money are you willing to spend for more punch in the higher powerband?
A custom Hytech/SMSP exhaust can put you back a couple grand, let alone the time they need to fabricate it.....Ive seen ITR cams go for 5-700 for a used set. It all depends on your financial standing. So think in between your means....
Good Luck
______________________
94' integra sedan SOLD
03' Yamaha R1 ltd. Ed.
02' BMW 330 Ci
02' Suzuki GsxR
JAYMAN320 is offline
» Site Navigation
» Home
 > FAQ
» Other Sites
