Originally posted by N2O'dturbocivic
Go to a hardware store, ask for a lugnut wrench, probably near the biggest one they have, ask to test it out real quick run to your car see if it fits, if not get a different size...shouldn't be that hard most places have something for the size of the bolt.
Sounds like you Don't know what the OEM wheel locks even look like.
CivhatchX,,, since you Don't have the lock number, You could go to a Dealer and they may have the key OR they could try to match or order a key.
I personally hate those things, and took mine off soon after I got the car ,"didn't pay for 'em." Besides, its a royal PITA to use the locks and key at the track. I already have to swap on wheels AND use different lugnuts.
Contact the dealership is your best bet OR you could contact the maker of the lugnuts McGuard I believe.
Worse comes to worse, you could Go to a garage or tire shop and they may can use a bolt/lock remover BUT, this usually ruins the lock and even this sometimes doesn't work.
Good luck,
A.
