Old 01-28-2005, 08:49 AM   #1 (permalink)
Car: 2001 integra ls
Mods: still workin on it
integra01 is an unknown quantity at this point
Exclamation ls/vtec or gsr which would be better
if i did a ls/vtec with turbo compared to a gsr with a turbo what would be better and what would produce the most hp and 1/4 mile times?
integra01 is offline
Old 01-28-2005, 09:09 AM   #2 (permalink)
Car: 94 Civic Hatch
Mods: intake
braIn_ceL is an unknown quantity at this point
ls/vtec
03 scoby wrx(stock.. for now)
97 hatch(gsr swapped) (skidmark)
R.I.P.
Padmé (94 civic hatch)
Trogdor (94 Integra LS)
braIn_ceL is offline
Old 01-28-2005, 05:46 PM   #3 (permalink)
Dark Wind
Snoopy's Avatar
Car: something with wheels
Mods: whole lot of nothing
the one thats built and tuned better
Snoopy is offline
Old 01-28-2005, 05:49 PM   #4 (permalink)
CRVTEC0WNZJ00's Avatar
Car: 1993 Civic Si
Mods: Too many
Yes, but the LS/VTEC would have slightly more displacement. My buddy Mannys hatchback is LS/VTEC turbo completely stock block B16 head with a turbo and all it does is smoke tires and its pretty BA.
2006 Laguna Blue Pearl S2000.
CRVTEC0WNZJ00 is offline
Old 01-28-2005, 06:44 PM   #5 (permalink)
so what should i use for something to run 11's or better
Old 01-29-2005, 10:05 AM   #6 (permalink)
solsykness's Avatar
Car: '93 Del Sol SI
Mods: check out my sig bish!
solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?solsykness you're still here?
what it comes down to is which one of the motors is tuned better...a turbo on any motor rocks but you are going to spend more money on putting the ls/vtec together bc it isn't a direct bolt-on affair...I would boost a gsr motor if you are going to boost anyways...the gsr motor is a performance motor to begin with so I would say try that, unless you really want to do the frankenstein swap...it basically comes down to what YOU want to do...the turbo project I am going to be working on will be for a d16z6, yeah I know SOHC...but I know this guy here in NC with a 550hp 3000gt, and from what he says...we should be able to get close to 300hp to the wheels...I'm hoping anyways...
solsykness is offline
Old 01-30-2005, 03:02 PM   #7 (permalink)
Car: 1994 Acura Integra
happycakes101 is a splendid one to beholdhappycakes101 is a splendid one to beholdhappycakes101 is a splendid one to beholdhappycakes101 is a splendid one to beholdhappycakes101 is a splendid one to beholdhappycakes101 is a splendid one to beholdhappycakes101 is a splendid one to behold
If i were you just boost the regular LS motor, its a better motor and trans to boost (lower compresion than GSR and long gears in the tranny). But do what the other guy said, DO WHAT YOU WANT? Cause its all been done before by someone.
happycakes101 is offline
Old 01-30-2005, 04:05 PM   #8 (permalink)
whiteGSR95 is an unknown quantity at this point
ls/vtec, but make sure that someone with experience building ls/vtecs does it for you.
btw this is a good site with ls/vtec dyno ### http://www.importreview.com/dyno.html
whiteGSR95 is offline
Old 01-30-2005, 05:25 PM   #9 (permalink)
SH Virus
Car: 1979 Porsche 911SC, 95 Chevy S-10, 2 1990 Miatas
Mods: Don't you wish you knew
hobie237 Hello down there miniscule peonshobie237 Hello down there miniscule peonshobie237 Hello down there miniscule peonshobie237 Hello down there miniscule peonshobie237 Hello down there miniscule peonshobie237 Hello down there miniscule peonshobie237 Hello down there miniscule peonshobie237 Hello down there miniscule peonshobie237 Hello down there miniscule peonshobie237 Hello down there miniscule peonshobie237 Hello down there miniscule peons
if you're talking about serious mods... it doesnt really matter too much which one you start out with...the gsr's arent too hard to work on...thats what my buddy's running and hes in low 12s...the vtec might be a little more streetable tho... the cams hes got make the idle pretty crappy...if you're looking for something that can do serious street and strip use... probly go with the vtec
hobie237 is offline
Old 01-30-2005, 11:53 PM   #10 (permalink)
Car: 94 Civic Hatch
Mods: intake
DAMN... with lots of boost. your gonna have to some serious. i dought thats on pump gas too.. good luck though. power to the sohc vtecs.
R.I.P.
Old 01-31-2005, 01:31 AM   #11 (permalink)
Car: nindy fo integra
Mods: intake, exhuast...de-ricing process
lude_dude_si is a splendid one to beholdlude_dude_si is a splendid one to beholdlude_dude_si is a splendid one to beholdlude_dude_si is a splendid one to beholdlude_dude_si is a splendid one to beholdlude_dude_si is a splendid one to beholdlude_dude_si is a splendid one to behold
i bet u could pass with some 10:1comp pistons and like a 6psi setup. i dont understand why ppl go 17-30psi of boost cuz when it FINALY spools up the torque hits so hard it completely breaks the traction on normal street tires and ends up costing u a shit load in the end. i think a perfect setup would be high comp pistons, low boost, mild cam and a few other misc pieces but i dont wanna give out all of my plans
edit:btw thats for a dailydriver/weekend drag setup
FREE MONEY Finally a free money site that pays.
lude_dude_si is offline
Old 02-07-2005, 01:40 PM   #12 (permalink)
Car: 98 base Prelude
Mods: livin' loud w/ Kickers all around
vietshorThi will become famous soon enough
yeah i say gsr..ls/vtec is pretty tough..and unless you're hella good at being mr. mechanic..it'll be unreliable
vietshorThi is offline
