Originally posted by 98integra
Pull the code
What code? Pls be more specific.
OBDII cars will download an error code if the ECU is having a problem. Any standard OBDII code reader can pull it. The code will be a number that will give you a general idea of the problem when you look it up in a table. If you do a search in Tech on codes, you will probably find more info. on how to do it.
Good luck with your project.
