Old 10-14-2007, 10:42 AM   #1 (permalink)
Iron Monk
Meso Teggy's Avatar
Car: 99 Acura Integra GS-R
Mods: Short Ram Intake, MagnaFlow Cat, Greddy SP2 cat-back exhaust
Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?Meso Teggy you're still here?
tech wrench manual transmission flush
i wanna do a manual tranny flush on mys gs-r at work...i just wanna be certain if i could use the same fluid that you use in the rear differential gear in the tranny
Meso Teggy is offline
Old 10-14-2007, 11:25 AM   #2 (permalink)
Use Honda MTF. Normally gear oil is thick (either 75w-90 or 75w-145). Temp usage of tranny fluid is same as engine oil, which is way thinner than gear oil.
female four is offline
Old 10-14-2007, 11:46 AM   #3 (permalink)
Iron Monk
Meso Teggy's Avatar
ok thanx for the info...i will try my local auto parts store or a dealership
Old 10-14-2007, 11:49 AM   #4 (permalink)
Iron Monk
d16y8alltheway's Avatar
Car: 1997 civic ex
Mods: i/h/e/ si tails/02 si wheels/high flow cat/type r headlights/mp3/wma player/
d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?d16y8alltheway you're still here?
you can't buy the mtf at the auto parts i tried and they said you can only buy it a honda.
it's like 5.39 a quart @ honda and you only need 3 and it's easier to change than an oil change to me.
d16y8alltheway is offline
Old 10-14-2007, 12:06 PM   #5 (permalink)
Iron Monk
Meso Teggy's Avatar
oh yeah i know that... just gotta pull the drain and fill bolts...the only thing i need is a funnel or whatever when adding
Old 10-14-2007, 12:11 PM   #6 (permalink)
Iron Monk
Car: 1997 civic ex
what i did it's this i bought a funnel .then i went to lowes and bought a piece of clear hose(they sell it by the foot) it cost me .98
Old 10-14-2007, 12:20 PM   #7 (permalink)
Iron Monk
Meso Teggy's Avatar
noice
Old 10-14-2007, 02:53 PM   #8 (permalink)
MQTGSR's Avatar
Mods: mAd JDM ShIT Yo!!
What do you mean by "Temp usage of tranny fluid is same as engine oil, which is way thinner than gear oil."
Are you saying he can temp. use engine oil as tranny fluid? I have never personally changed the tranny fluid, but it is separate, and what kind of fluid is Honda MTF, is it more like an ATF or more of a gear oil?
My rides:
MQTGSR is offline
Old 10-15-2007, 07:23 AM   #9 (permalink)
Up until the new Honda MTF's came out, the Helms called for use of 10w-30 motor oil in the tranny (manual not auto) for temporary usage. That means when you don't have any tranny fluid around. And when you have the chance to, change it out for the proper fluids.
As mentioned earlier, gear oil is thick. In the rage of 75w-90 compared to the 10w-30 that the manual suggest as temporary fluid for the tranny. So with that info, its obvious that the gear oil's weight of 75w90 is too thick for the tranny.
Honda MTF is basically tranny fluid, but with their own additives for the manual tranny. The auto tranny fluid is basically Dexron fluid with their own additives. It is highly recommended to use only Honda fluids considering you can't add the additives afterwards like many other manufacturer's do on their diffs.
Old 10-15-2007, 07:32 AM   #10 (permalink)
MQTGSR's Avatar
Ok, thanks, now that makes sence. Well the last time my tranny fluid got changed was at the usual shop I take the car to. I assume he would have used a product equivalent to Honda MTF if he didn't already use it. Well i May change it anyway here soon before I put the car away for the winter. If I don't do it now, I will prob. do it next spring.
My rides:
MQTGSR is offline
Old 10-15-2007, 07:34 AM   #11 (permalink)
Many people use redline or any other fluid made for manual trannies. It shouldn't harm it at all as long as you use the correct stuff, and not excessive oil weights.
Old 10-15-2007, 09:47 PM   #12 (permalink)
FuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peons
They actually sell funnels with the hose attached nowadays at Kragen. I know because i just had to switch fluids.
The Tranny has to go w/o a fluid flush for quite some time so why not just buy the Honda stuff and be done with it?
FuNkDr.SpOt is offline
Old 10-15-2007, 09:50 PM   #13 (permalink)
Iron Monk
Car: 1997 civic ex
werd it's not that expensive only 5.39 or so at honda all you need it's 3 quarts(more like 2.4)
Old 10-16-2007, 05:10 PM   #14 (permalink)
Actually, I JUST did my tranny and it holds MAYBE 2.1 at most. It was starting to drip back out at about 1.9 but i kept filling.
Old 10-22-2007, 04:59 PM   #15 (permalink)
8urcivic's Avatar
Car: 99 ls/95gsr
8urcivic In the rep troposphere
