Old 06-16-2008, 11:12 PM   #1 (permalink)
gsrkid1994 is on a distinguished road
need helpfull advice about a n/a all motor gsr
hello i have a gsr. 94. p28ecu. not sure what chips in it but i know its socketed and chipped. I have je piston 12 to 1 compression pistons. eagle rods, rc310 injectors, crane turbo cams, exahust, fuel rail, msd digtal sci,etc. i was wondering. first off how seroius would i need a tune and could it drive it 30 miles on the highway.2, how can i have someone tune it would i need to get a new blank chip for my ecu. 3, would i need to go back to gsr stock cams for the reason that my crane cams are turbo. and how realible and guessing how much hp and whp i might have. any help would be great.
gsrkid1994 is offline
Old 06-17-2008, 06:07 AM   #2 (permalink)
MQTGSR's Avatar
Mods: mAd JDM ShIT Yo!!
I'd swich cams and get a decent tune. You should be able to drive your car daily unless you get some crazy aggressive cams or something and cant have a street-able car.
That should be all you need. I'm guessing you'd be around 180-200whp
My rides:
MQTGSR is offline
Old 06-17-2008, 04:46 PM   #3 (permalink)
help still
ya why are you not supposed turbo cam in a n/a motor?????? it came with them in it and i just had the motor rebuilt all brand new internals...all ready timing and its actaulyy running not all that bad but please post back
Old 06-17-2008, 05:42 PM   #4 (permalink)
CapnToll's Avatar
Car: 1996 Integra SE
Mods: See the sig.
The lift and duration on the lobes of the turbo cam are specifically designed to work with the high amount of air entering the cylinders. By design, they just won't give you that big extra bump in power that cams designed for your NA motor will. You can get NA cams to take advantage of your higher Compression Ratio. I think Skunk2 Pro2 Cams would be great at 12:1 (most people think the Skunk2 Pro2 still overcam motors at mid 11:1 CRs, but 12:1 should be perfect to get the most out of Skunk2 Pro2s).
How high are you revving the motor? You should be fine for 10,000 yes? (Just asking because I'm not quite sure of the difference between the Type R and GS-R block design...I know the stock bottom end Type R can take close to 10k)
1996 Acura Integra SE
Motor: BC0022 Cams, Crower V/T, AEM Cam Gears, Comptech Icebox, Skunk2 I/M w/ Hondata gasket, DC-S 4-2-1 Header, 2.07" Brullen Cat-Back, B&M FPR, FAL Rad/AC Fans.
Tuning: UBERDATA, FJO Racing Wideband AFR System/Gauge
Security: Computer chip ignition Immobilizer, Intrusion alarm, Glass break alarm, and of course... THE BAR!!
Old Dyno: 175whp @ 7500 RPM / 135wtq @ 7000 RPM........ERTW
2001 Toyota Highlander V6 4WD - Winter Car - 220bhp / 222tq Bone Stock Baby!
CapnToll is offline
Old 06-18-2008, 08:34 AM   #5 (permalink)
ok so its not all that bad?
so its not bad to have these cams in they won't destroy my motor right??? cause they were put in by an engine building shop who did my engine so i really don't want to mess with my timing and all. but with a tune from a good shop wouldn't it be just fine. my motor would blow.right??
Old 06-18-2008, 01:13 PM   #6 (permalink)
MQTGSR's Avatar
your motor will not blow or damage itself with turbo cams, your just going to be lower on power with that setup than you should be. Get a good set of N/A cams and have someone install it if you cant do it yourself and get a tune.
\Thread
My rides:
MQTGSR is offline
Old 06-18-2008, 04:35 PM   #7 (permalink)
kool thanks
thanks for the info a guy from team integra was telling me they'd destroy my motor. can i have a reputable tuner tweake my car with my cam gears and cams to smoothen out the idle and then tune the rest of it with crome
