Old 01-23-2004, 11:13 AM   #1 (permalink)
GunMetal Member
Car: 1996 Integra LS
Mods: Eibach Pro Kit, Koni Yellow shocks, Neuspeed short shifter, Neuspeed front strut brace, DC header, Iceman intake
Iceman16v Rep God/GoddessIceman16v Rep God/GoddessIceman16v Rep God/GoddessIceman16v Rep God/GoddessIceman16v Rep God/GoddessIceman16v Rep God/GoddessIceman16v Rep God/GoddessIceman16v Rep God/GoddessIceman16v Rep God/GoddessIceman16v Rep God/GoddessIceman16v Rep God/Goddess
tech wrench Next reliable mod after I-H-E?
I need some suggestions as to the next best reliable mod after I-H-E. I have an LS, so no vtec to mess with. Would a high flow cat be the best thing? Pulleys? What are pros and cons of underdrive pulleys?
Thanks guys
Iceman16v is offline
Old 01-23-2004, 12:09 PM   #2 (permalink)
GunMetal Member
Car: 1992 Integra GS
Coletrain25 is an unknown quantity at this point
Re: Next reliable mod after I-H-E?
Originally posted by Iceman16v
high flow cat
:t2
Coletrain25 is offline
Old 01-23-2004, 12:19 PM   #3 (permalink)
Car: 1999 Integra GSR
DaWickedOne is an unknown quantity at this point
Yes get a Carsound Hi flow cat
as far as the pulleys go read this thread:
Pulleys
DaWickedOne is offline
Old 01-23-2004, 12:35 PM   #4 (permalink)
GunMetal Member
So is Carsound the best bet for hi flow cat? What about a Random? Carsound better?
Old 01-23-2004, 12:37 PM   #5 (permalink)
yea you would be better off getting a carsound, i dont know much about random but if thats easier for you to get im sure there arent too many significant diff. between the two.
Old 01-23-2004, 12:44 PM   #6 (permalink)
GunMetal Member
Does Carsound come in a bolt-up application or is it straight weld? I'd rather have a bolt-on cat
Old 01-23-2004, 12:48 PM   #7 (permalink)
They are universal cats but if you take it to a muffler shop they can weld on flanges so then it will bolt to your exhaust.
Old 01-23-2004, 05:01 PM   #8 (permalink)
Car: 1999 Integra Gsr
pbizzleGSR is an unknown quantity at this point
ipsracing.com sells them bolt on i believe..im going to be buying one soon also..
pbizzleGSR is offline
Old 01-24-2004, 08:52 PM   #9 (permalink)
NationsMostWanted's Avatar
Mods: STOCK
are these still obd1 cats? is the obd2 cats still a dealer item?
NationsMostWanted is offline
Old 01-24-2004, 08:55 PM   #10 (permalink)
GunMetal Member
so whats the diff: obd1 vs. obd2
"My car's not slow, it just has a low metabolism."
1996 LS|Iceman CAI|DC 421|Evo|Neuspeed Sport springs|Koni Yellows|Neuspeed front brace|Neuspeed short shifter|AEM Pads|Duralast rotors|14" Stocks with Kumho Cheapies
Old 01-24-2004, 09:50 PM   #11 (permalink)
Mods: STOCK
OBD2 cats have an O2 sensor on it
Old 01-24-2004, 10:08 PM   #12 (permalink)
2 actually, well at least mine does
1 pre-cat and 1 post-cat
Old 01-24-2004, 10:58 PM   #13 (permalink)
clayton's Avatar
Mods: yes, please.
the carsound cats have a thing sticking out of it where i always figured you could mount an o2 sensor.
edit:
^from magnaflow's site
edit2: http://www.car-sound.com/04product/04obdii.htm
Originally Posted by B-rex;
clayton is offline
Old 01-25-2004, 12:25 AM   #14 (permalink)
Car: 94 INTEGRA GS-R
Mods: H22 at last!!!
slim9300 is on a distinguished road
I say a Apexi Super AFC II or a Greddy E-manage. They run about $300 and both are probably the best two piggyback units for hondas. This will give you the ability to tune your fuel settings and will be critical for down the road if you ever get cam shafts, cams gears, nitrous, aftermarket intake manifold, or pretty much any mod that allows your vehicle to burn more fuel efficiently.
Oh yeah, you are probably better off geting a ACT Prolight Flywheel though (8.8lbs.), they run about $250. When I used to have an LS motor, I had i/h/e and none of their power gains compared to the flywheel. However if you are going to change the flywheel, you should probably change the clutch too. Exedy makes a good racing/daily driving clutch for about $300. Sorry, I hope you have alot of money because as you probably already know parts just keep getting more expensive the farther you move along.:eek
‘95 Integra GS-R Hatch
Engine/tranny: JDM H22A w/ Factory LSD, HCP Mount Kit, Exedy Organic Clutch, Greddy EVO Exhaust, Custom SS Header, AEM SRI, P72 tuned w/ Uberdata, PWR Radiator, Forbidden Motorsports Short Shifter, Trunk mounted Optima Red Top Battery.
Handling/Stopping: Koni Yellow Struts, H&R Springs, Danny Tran Racing Traction Bars, Spoon Rear Strut Bar, ITR Front Strut Bar, Brembo Drilled and Slotted Rotors, Brembo pads, SS Brake Lines, Yokohama ES-100 205/40/17, 17’’ Momo GT2‘s.
Ice/Interior: Alpine CDA-9835 deck, (4) Pioneer 6.5'' 3-way speakers (200 watt), 2001 GSR Full Leather, Autometer Bezel Gauge Pod, Autometer CF Oil Pressure gauge, Autometer CF Air/Fuel Ratio Gauge, Skunk 2 Shift Knob, ITR Shift Boot, etc.
Future Plans: JDM ITR Front End Conversion w/ Gunmetal H.I.D. Headlights, 17’’ Work Emotion Gunmetal Wheels, ITR Spoiler, OEM optional Side Skirts, Shaved side moldings, Kandy Apple Paint.
slim9300 is offline
Old 01-25-2004, 02:43 AM   #15 (permalink)
IntegraXTR's Avatar
hi flow cat or clutch mebbe?
i'd reconmend doing a total flush of the fluids and add ss lines and upgraded pads for your brakes..
mebbe tires also?
there's a lot of stuff you can do?
do you want power stuff? or say, like upgrade your suspension?
what are your goals?
ENDLESS GARAGE : ::custom fabrication::dyno tuning::service & maintanance::
www.myspace.com/integraxtr
IntegraXTR is offline
