O2 sensor
Anyone have any experiance with O2 sensors? I plan on replacing mine but I dont know if one brand is better than the other, and what brand is best. OEM units are about $200 but aftermarket ones range from $20-$60.
__________________ 1991 Acura Integra GS(Sold ) 1994 Prelude SI
Bosch and Denso makes o2 sensors.... for the Bosch OEM (meaning it comes with the sensor, wires and connector), u're looking at abt $120+, while denso OEM is abt $90+.... if u find $20 sensors, u know the rule... u get what u pay... btw, i have hook-ups for o2 sensors.... not denso, but quality is the same... lemme know
The more expensive ones are plug and play units. No soudering required. The lesser ones you have to cut your carness and souder it onto the new sensor, I used this type. I couldn't see paying over $100 more to have the plug already on it....
Assuming your car is basically aa 92 LS engine (should be the same for the GS anyways), you'll need this NGK/NTK part 24033 or this Denso part 234-1017. You choose. They are both plug and play, at least I know the NGK/NTK one is. So $25-$30 depending on which one you want.
The NGK/NTK one is slightly cheaper. The 92 GSR though uses the same sensor as the one I got above, the 24172. Otherwise, just get the other one listed.
Nevermind, just say your sig, you have a 91. Either way, just use the site search feature and it'll tell you what you need. Should pretty much be the same though.
Edited the part numbers to reflect your year and model teg. Its also cheaper for the O2 sensor too. $20-30 depeding on which brand you want, which are both good btw, is pretty cheap for plug and play.
The universal NGK/NTK one sells for $18. But for a couple of bucks more you could get one thats pain free and clicks right in.
I know the 91 sensor is different than any of the newer sensors and cheaper too. Thanks for the link female four. Im going with NTK/NGK since I've personally had problems with Bosch plugs.
