Originally posted by wU-rAcEr
i have a stock o2 senor adn i get good readings
i believe, if it works then leave it alone
It's not that your o2 sensor isn't working, its that stock o2 sensors typically output various results in direct correlation to the exhaust gas temperature. If you are under boost, and running a richer mixture such as 12.5:1 then I would say spend the money for a wide-band o2 sensor. Your stock o2 sensor is going to be the most effective somewhere around the 14.7:1 range, although as I said earlier the output voltage reading will vary in relationship to the exhaust gas temperature. A wide band o2 sensor can more accurately display A/F ratios from 10:1-20:1, and I believe they operate on a 0-5v scale opposed to the stocks 0-1v reading.
If you have the autometer gauge I am thinking of (the one with the circular lights) you should be fine.
