Ok, I have an 87 D16a1 Integra, I just rebuilt the head. Only 35 miles on it, when I drive it more than 5 miles it is like the car loses compression and drops RPM. When I depress the clutch it acts as the brakes and stops the car. I'm confused. Plus my #4 cylindar plug wires keep popping out, sometimes #1 also.
Well, I sent the head oiff to get rebuilt and they replaced the valves b/c they were bent, new distributor, I think my rings are shot causer it smokes like hell
Ide have the head install and rebuild looked at by somebody else. a fresh pair of eyes may help but it sounds lke something wasnt put back right.
Mods: ICEMAN Cold Air Intake, AEM Underdrive pullies, MUGEN strut tower bar, R1 Racing Coilovers, Mugen Short throw shifter
i have a friend who bought a Haynes manuel for his 96 civic which is also the one for my integra and that has helped me sooooo many times. def worth the money to get one. have you contacted the shop that did the work??? sounds like they owe you some money or some free work.
98 integra
iceman CAI
K&N Filter
DENSO plugs
AEM underdrive pullies
R1 racing coilovers
Ractive Short Throw (70%)
16x7 BORBET Type E
BF Goodrich G-Force Sport 205/40R16
and more to come...........
Actually alot of shops will tell you the valves need to be adjusted after the install. It is always a good idea to check others work.
Originally Posted by got-vtec?
Would it be safe to go about 180-190 mph on the street in a lightened crx.
Yup. They do a pressure & vacuum test on the head to see if its holding or leaking. Thats how they test it. So all the springs are loose when it comes out of the shop. You must adjust the valves afterwards. You can't just slap them on.
Originally Posted by 87d16a1
Do you know of a site that has the factory specs for the 87 I can't seem to find one
