04-26-2008, 03:52 PM
#1 (permalink)
Mods: mAd JDM ShIT Yo!!
A question about an alignment.
So as some of you may know, I just put 2in. lowering springs on my car, along with Koni yellows.
I have heard conflicting points of view as to weather I should get an alignment or not. I have made no other adjustments other than replaceing some oem bushings with poly ones, and the springs/struts. I dont think this would throw off your alignment would it??
It does not pull wierd or drive funny, I just want to know for sure weather I should get one or not.
My rides:
04-26-2008, 06:43 PM
#2 (permalink)
Car: 1988 CRX SI
Mods: D15B2 w/PM6: pacesetter headers, tanabe 2 1/4 exhaust system, ZC tranmission, B&M short shifter, "Custom Shift Linkage", "aftermarket" intake, "8 yr old" tanabe lowering springs
worn bushings can throw off alignment spec but if you replaced them you should be ok
i think the only thing lowering can really effect is camber
04-26-2008, 08:43 PM
#3 (permalink)
yeah your camber in the front and toe in the back (which are set by factory spring height and cannot be adjusted). you will have bump steer my friend. And you'll also eat your tires prematurely. Camber/Toe kits are all over ebay for hondas. check it out.
04-26-2008, 08:49 PM
#4 (permalink)
Car: 2000 Honda Civic Ex Sedan
Mods: Smoked headlights, clear Si fogs, 17x7 rims (bout to be 16x7 Konigs,) Type R lip and grill (goin back to stock grill soon,) Password:JDM rear strut bar, full custom stereo, Password:JDM CF/Kevlar intake, F2 Type 1 Coilovers awaiting install
^  Any time you alter your suspension you need an alignment. Doesn't mean anything necessarily has to be changed but you want to check camber, toe, and caster to make sure there within spec. 1 or 2 degrees of negative camber isn't too big a deal, but it will wear your tires unevenly. Trust me, I've been there. I lowered my '92 Accord about 3-3.5" and the camber was wayyy off; the tires ended up wearing out quicker and unevenly (more on the outside.) Camber kits aren't that expensive, I'd look into it...
04-26-2008, 10:34 PM
#5 (permalink)
Car: 96 hatch
X2 you cant tell with the naked eye but it out of alignment
04-26-2008, 11:23 PM
#6 (permalink)
Especially if its is a daily driver. And on how aggressively you drive...I run close to -3/-2.5 and a good amount of toe out up front and get decent wear...but I abuse the car on mountain roads, auto-x...etc etc fairly regularly as well as a good amount of highway driving.
I've only dicked around at home with adjusting toe up front...but I would recommend getting an alignment after looking into the camber kits.
04-27-2008, 02:00 AM
#7 (permalink)
Hm, I mean this is a very slight drop, and I drive it kinda hard on the roads at times and occasionally auto x. My tires wore more out the outsides when stock, so idk how bad it will be with a 2in front drop and 1.7in rear.
How much of a pain are these camber kits?
Basically what I am hearing is I should get one of these then get the alignment because you cant adjust some settings without these kits.
My rides:
04-27-2008, 06:04 AM
#8 (permalink)
Car: 1988 CRX SI
im not sure what come with the kits but i know many cars have a way to adjust camber..(shims, drilling)
the shop you get an alignment will mostly likely do it for you but im guessing the camber kits make it easier
04-27-2008, 12:51 PM
#9 (permalink)
your tires wore out on the outsides from aggressive driving. Hard turning. and the kits are easy as pie to install. The front camber kit is usually an adjustable top plate that you replace with your stock one, in the rear not sure, there's an arm you replace by an adjustable one. I've heard it been called the smart arm.
I don't know any other way you could adjust the cmber, unless you drill a new hole in the top plate for the upper ball joint to move into. That can't be safe. Or drill holes in the frame to move the topplate there (where it bolts to the shock tower)
Anyways, i lowered my civic 2" front 1.75" back and my tires laster 2 summers. The second summer they were down to the steel belts. I had no idea cause i got an alignment done and the guy said everything was cool. FUcking bastard. Point is i looked into it and you can't change those two adjustments. You need a kit, they are cheap and they are safe. FULLY adjustable too, so when your springs start to sit down in a couple of years, you can readjust.
Reason: forgot something
04-27-2008, 02:28 PM
#10 (permalink)
Car: 98 GS-R
i would go and get the alignment 1st. That is what will tell you if you need a camber kit. When I did mine I told them to use ITR specs because it is a little lower than the gsr stock. I didn't need a kit on the rear but the front i did.
04-28-2008, 01:58 PM
#11 (permalink)
Dark Samurai
Car: '98 Integra LS hatch
Mods: See website in sig.
ANY time you install different parts or change the suspension in any way, the act of taking it all apart and putting it together changes your alignment settings. You have to get one if you want to avoid irregular/fast tire wear, unless you are somehow extremely lucky and get all the settings within spec by chance, although then you won't know until it's possibly too late.
As for camber, see how many degrees you have when you get the alignment. If it's -2.0 or below you should be good as long as you have the mechanic set your toe angles to 0 during your alignment.
http://www.freewebs.com/white98ls - don't forget to sign the guestbook!
04-28-2008, 06:00 PM
#12 (permalink)
Dark Wind
Car: 93 civic dx
Yes, you should do an alignment after you install suspension parts.
Have them set the TOE to 0 and see how off the camber is.
Anything from 0* to -2* its ok for the street. Anything from -2* and down you need a camber kit.
1991 Galant VR-4
1989 Camry -daily beater
1993 Civic dx-sold
1991 Eclipse gsx-sold
04-28-2008, 10:38 PM
#13 (permalink)
Making my alignment appointment tomorrow, thanks for the input guys, a real help.
My rides:
04-29-2008, 11:09 AM
#14 (permalink)
Actually you're all right, the integra seems to have less issues with lowering than civics. I was thinking about my civic. My friend lowered his integra the exact same and he doesn't need a camber kit.
I don't understand why though, i thought the susp. parts were all the same. And my alignment was all set to spec, just that he didn't touch the camber. If anyone could shed some light on that it'd be great. Is it my 17"? Will larger rims accentuate the camber?
04-29-2008, 11:16 AM
#15 (permalink)
Maybe? I know there are lots of things to consider when changing wheels, like offset, backspacing and whatnot.
I should have thought about camber issues when I bought the setup, it totally skipped my mind, but we'll see what happens, It would be nice if I dont need one as I am shit for money right now.
