Originally Posted by hidiouskinky
ok guys....i have spun a bearing and i have decided to rebuild the bottom end....my head has been equiped with skunk2 pro series valve train....im going to b boosting in about a yr....i know i have to do some honing and what-not to the block....im adding race bearings to the mix....im pretty much doing what i can except adding lower CP....can anyone out there give me any advise as to what size i need to hone the bottom end out to....any help would b GREATLY appreciated
There are so many variables to what you could do that you need to narrow it down for us. Do you already have a plan? Have you done REAL research into what you're planning on doing and what your goals are? If you have, your questions should be more specific.
Also, please try to use the enter key once in a while instead of adding those....every sentence as it spaces the paragraph out for us to read much easier.
