Shitty Drivetrain engagement?
I was at the mall with my girl last week and it i was really cold at night like around 20 degrees outside. Anyhow i started my car up and it was fine and let it warm up a little before driving it. Well not the who car shakes at low rpms in 1st and 2nd gear and i can feel vabrations in the pedal at high rpms but i'm not having any clutch slippage. The shop said they checked the mounts an the tranny said that they were worn but weren't causing the issue. The said it isnt' the throw out bearign or low clutch fluid either. Anybody have any suggestions
__________________ =SLOW!!!
Originally Posted by parish
Check your wheels but recently have you hit any pot-holes or anything like that? Are you on top of your tire pressure and also are you running low profiles (205-40-16, somthing like that)?
my steering wheel shook when the tires were worn uneven, not the pedal. any other wierd symptoms. BTW what pedal, gas or clutch? if its the clutch there may be air in the lines...idk i'm guessing here.
clutch pedal and my alignment is off do you think that is the problem. My steering wheel is turned slightly to the right while i'm going straight? i'm running 15" LS mesh rims stock tires. the pressure is fine in them.
An alignment will have nothing to do with shaking. Tire balance would, a tire coming apart would, a bent rim would, a warped flywheel would give you vibrations as you change gears. An axle going bad might give you a vibration also.
thanks i appreciate it.
Originally Posted by type-sman
i would say a axle cold be it to do you feel it when you are in high gear ?
The car doesnt' vibrate in higher gear but i do feel the vibration in the pedal at that point. Do you think my suspension will blow up if i drive it for a couple of days till i get it fixed? Like 3 days...
Ok so i took my mom's car back to school and used that for the time being. I get back and start her up and now she drives just fine. No vibrations or issues at all wtf
