Old 11-26-2004, 06:13 AM   #1 (permalink)
Car: Honda Integra
Mods: DC4
tegstar83 is an unknown quantity at this point
spoon engine's where to get?
Spoon engines are crazy,
my questions is where do u go to buy one and how much are they?
Im after the B18B ( i think thats the code but I know thats close)
tegstar83 is offline
Old 11-26-2004, 06:54 AM   #2 (permalink)
Car: 1991 Acura Integra GS
91Integracer Needs to go outside once in awhile91Integracer Needs to go outside once in awhile91Integracer Needs to go outside once in awhile91Integracer Needs to go outside once in awhile91Integracer Needs to go outside once in awhile91Integracer Needs to go outside once in awhile91Integracer Needs to go outside once in awhile91Integracer Needs to go outside once in awhile91Integracer Needs to go outside once in awhile91Integracer Needs to go outside once in awhile91Integracer Needs to go outside once in awhile
www.inlinefour.com
rspeed.org
jordanpolizzi.com
Snapshot Of The Day
"I'm the photographer!!! NOT the hot chicks in my pictures!!! Guys please stop sending me pictures of your D!@&'s WTF!!!"
91Integracer is offline
Old 11-26-2004, 01:26 PM   #3 (permalink)
Dark Wind
Snoopy's Avatar
Car: something with wheels
Mods: whole lot of nothing
wow. spoon engines are not crazy. you could build an engine that makes more power for much less than a spoon LONGBLOCK alone costs. so tell me. what makes it so crazy? because its spoon and jDm y0! do you even know what comes in a spoon crate engine?
Snoopy is offline
Old 11-26-2004, 01:58 PM   #4 (permalink)
Dark Wind
Snoopy's Avatar
and to fancy your pickle some....
- it is a new 98 spec R longblock
- internal components are JDM OE Honda with the following exceptions
- it is fully balanced and blueprinted
- it uses the Spoon 2 piece headgasket for a compression ratio of 11.3:1
- it uses the Spoon oil pump which is stronger and more effective than the OE Honda one
- it should put out around 180hp at the wheel
what is 'balanced and blueprinted by Spoon'?
- all engine components are weighed to 0.01grams precision
- engine components such as pistons and rods are balanced, they all weigh within 0.01gram of each other
- Spoon is able to balance these components because they order/weigh/sort hundreds of pistons, rods, etc. from Honda and sort them into balanced sets
- bolts are torqued within 0.01N/M of Honda specs
- what does balancing and blueprinting do? it makes the engine run incredibly smooth, reduces power lost to inefficiency, power delivery is extremely smooth, power is higher across the entire rpm band compared to a Honda assembled engine, engine/throttle response is much better, the engine revs smoother/faster and is able to withstand high rpm better, engine life is improved considerably especially in race environments
why does Spoon offer this engine?
- Spoon's core philosophy is in balance: good power, good driving feel, and long life. this engine offers all
- circuit racing requirements differ from drag racing: an engine with the aforementioned characteristics is preferred in circuit racing over a high power, less reliable engine which might be favored in drag racing
- these engines are frequently bought by pro race teams competing according to FIA Group N regulations which require stock internal motors. hence they need an engine which has maximum effectiveness and efficiency using stock parts
who should consider a Spoon engine?
- pro/amateur racers requiring a motor in stock trim (FIA Group N)
- circuit racers/enthusiasts who want an optimized stock motor for circuit use
- people who want a new stock or reliable motor with decent power
who shouldn't consider a Spoon engine?
- drag racers
- people on tight budget or DIY
- people who want a high power setup, N/A or Turbo
- people who don't care about or aren't sensitive to subjective intangibles such as driving feel or engine response
what is the price of a Spoon engine or block?
- it is priced comparably to the price of a new b18c5 longblock/shortblock from Acura considering the work Spoon has put into it
- remember it is a NEW longblock/shortblock
- price fluctuates with supply and demand, although spoon engines aren't common here, remember that they are very common and popular in Japan and Asia
- expect price to increase over time as the supply of b18c components dwindles
- contact an authorized Spoon dealer such as IPS, R&D, A&J for a price quote
does/why doesn't Spoon offer a high power engine?
- again, Spoon's philosophy is balance. to Spoon, high power is only worthwhile if the engine can endure the stress of a 24 hour race. to Spoon, a street tuned engine needs to be comfortable and reliable while delivering improved power and driving feel
- Spoon has built and sold high power engines with 200+whp... high compression kits and stroker kits including a 2L kit for the 18C. However, the reliability and engine life of these engines still aren't good enough for Spoon's standards and hence Spoon does not offer them anymore
- Spoon doesn't drag race
so you wanna spend 6-10k on a stock honda engine thats been balanced and blueprinted, oh and of course slapped with the spoon name. yay for you!
Snoopy is offline
Old 11-26-2004, 04:26 PM   #5 (permalink)
Car: 1995 GS-R
Mods: soon to be a all motor b18c1 biatch........that's all you need to know
akmer You need a lifeakmer You need a lifeakmer You need a lifeakmer You need a lifeakmer You need a lifeakmer You need a lifeakmer You need a lifeakmer You need a lifeakmer You need a lifeakmer You need a lifeakmer You need a life
well if the guy is inlove with spoon, or just like spoon performance parts, let him do it. i mean he is just asking where to get it, fi yall are gonna be saying that stuff. and this and that. dont post if is not to help him on what he asked. just my .2 cents
but then again. i would not buy a spoon engine. to much money
www.texasracers.com
95 Integra GS-R......wrecked
now owner of a 94 Probe GT
hotshot- headers
hotshot- intake
phenolic spacers
jj- test pipe
KLZE Intake manifold
PROsupercharger on the way + NX 100 shot :clap
akmer is offline
Old 11-26-2004, 04:58 PM   #6 (permalink)
Dark Wind
Snoopy's Avatar
just trying to spread informantion here. he doesnt have to listen to what i say. nobody does.
Snoopy is offline
Old 11-26-2004, 07:26 PM   #7 (permalink)
Car: 1995 GS-R
iknow foo, i was just joking
a little sarcasm.. heheh
www.texasracers.com
hotshot- headers
hotshot- intake
phenolic spacers
jj- test pipe
akmer is offline
Old 11-26-2004, 09:51 PM   #8 (permalink)
Dark Samurai
Car: '98 Integra LS hatch
Mods: See website in sig.
LOL exactly what I was gonna say. "They balance the internals n bump compression by a fraction of a point... THOSE GUYS ARE JUST OUTTA CONTROL MAN!!!!!!" Revolutionary, ground-breaking shit Spoon's doing.... good lord $6k is a STEAL!!!
White98LS is offline
Old 11-27-2004, 02:40 AM   #9 (permalink)
Car: Honda Integra
Mods: DC4
WELL u certanly think u know it all u cunt! y dont u go out and buy best motoring vol 4 - roaring vtec and take a look at a mildly worked spoon engine in an old civic and see for urself what spoon is capable of u fucken dick!
Old 11-27-2004, 03:03 AM   #10 (permalink)
SH Virus
flyracerx's Avatar
Car: 98 Acura Integra
Mods: Not enough.
there is no spoon
Paolo
flyracerx is offline
Old 11-27-2004, 02:48 PM   #11 (permalink)
Dark Wind
Snoopy's Avatar
touchy much? and yes i do think i know everything thank you very much.
and you can go ahead and spend $6k for the spoon name and still get spanked by someone who know's what they're doing and dont buy things based on their name. besides....mugen > spoon
Snoopy is offline
Old 11-27-2004, 03:27 PM   #12 (permalink)
projecthatch92's Avatar
Car: 92 Civic hatch
Mods: mad turbo boost
projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?projecthatch92 Why haven't you checked into rep rehab yet?
werd
projecthatch92 is offline
Old 11-27-2004, 11:14 PM   #13 (permalink)
Dark Samurai
ditto. Name calling just puts someone on a lower level.
I do have that video on that computer. It is not that amazing. And can certainly be acheived with something less ridiculously expensive than the SUPER CRAZY EXTREME MEGAPOWER Spoon engine. News flash - those cars are fast because they weigh nothing, not because they're packing TONS of power from some wonder engine. Basically a stock balanced engine, nothing more.
Old 11-28-2004, 12:09 AM   #14 (permalink)
SH Virus
flyracerx's Avatar
Mods: Not enough.
we should have an owned smiley.
Paolo
Old 11-28-2004, 04:40 AM   #15 (permalink)
