Old 10-19-2007, 08:09 PM   #1 (permalink)
magnum434's Avatar
Car: 2000 Acura Integra GS
magnum434 is an unknown quantity at this point
Squeek after clutch is pressed.
Hey. So here's my problem. When I'm driving around, any time I press the clutch in, there is a squeek (it sounds like something is spinning and then slowly stops). The squeek will fade to nothing within about a second. It squeeks when I press in the clutch or if I just let off the gas and let it coast. It'll do the exact same. Squeek, and then fade away. What's going on here? Thanks.
magnum434 is offline
Old 10-20-2007, 02:13 PM   #2 (permalink)
FuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peonsFuNkDr.SpOt Hello down there miniscule peons
It could be a couple of things but most likely it's either your slave cylinder or your clutch wearing out.
My car used to do the same thing before I did a clutch change. One of the major things I did ( And i heard of others doing to get rid of the squeak ) is to use lithium grease to grease up the point between the slave cylinder and the release fork.
I say it might be the clutch because the slave shouldn't be making a sound like it's spinning at all, so maybe it might be a clutch spring and the clutch going out.
FuNkDr.SpOt is offline
Old 10-21-2007, 06:17 PM   #3 (permalink)
Car: 2000 Acura Integra GS-R
Mods: AEM V2 intake, HKS catback, Neuspeed lowering springs
AngelSol is an unknown quantity at this point
Another thing not to rule out is the fact that your TOB(Throw out Bearing)/Release Bearing might be starting to go bad!
I can go from 0-15 seconds in 15 seconds FLAT!!
AngelSol is offline
Old 10-22-2007, 02:10 PM   #4 (permalink)
Yeah, that's after you check the slave cylinder first. Slave cylinder = 15/20 min
bearings = tranny drop = 3/6 hrs.
Old 10-22-2007, 07:42 PM   #5 (permalink)
8urcivic's Avatar
Car: 99 ls/95gsr
8urcivic In the rep troposphere8urcivic In the rep troposphere8urcivic In the rep troposphere8urcivic In the rep troposphere8urcivic In the rep troposphere8urcivic In the rep troposphere8urcivic In the rep troposphere8urcivic In the rep troposphere8urcivic In the rep troposphere8urcivic In the rep troposphere8urcivic In the rep troposphere
dont forget the output bearing on the tranny its self.
why would the slave cylinder make it squeak?
8urcivic is offline
Old 10-22-2007, 08:46 PM   #6 (permalink)
The slave cylinder has been known to make noises and squeak if the point between the slave and the release fork isn't greased up periodically.
Old 10-22-2007, 08:48 PM   #7 (permalink)
8urcivic's Avatar
Car: 99 ls/95gsr
never heard of that...i heard of seized cylinders and busted ones......never noisy ones.
8urcivic is offline
Old 10-22-2007, 08:59 PM   #8 (permalink)
Had a squeaky one myself. It's actually in the service manual when you do a clutch change to grease that little ball at the end of the slave cylinder and the groove where that ball shaped end sits at the release fork.
