hey... i was hoping some of you fellow integra owners can help me out ....
when i start the teg for the first time during the day, the engine shoots up to 3K RPM and stays there for like a minute or 2.... does anyone else have this problem?.. and can anyone give me a problem with my car?
When the engine is cold, the car will be in cold start mode. It will idle high. The only thing that matters is if it comes down or not. If it idles fine after the car is warmed up, then its normal.
Gas mileage is based on how much throttle you are using, not how high the car idles during cold start ups.
Mods: STOCK
Originally posted by x0SUPERMONKEY0X yeah i turned the screw down ... before it ALWAYS stayed at 2K.... i was getting HORRIBLE mileage for a honda.. so i turned it down.. and its good...
none of the other cars does that... my old hatch didnt do this either... it just stays up at 2500 until the engine heats up
its normal for a car to be high when its cold.
__________________ 2008 Infiniti G35 Sedan Blue Slate/Graphite Interior:Sports and Premium Package 5AT, 2008 Mercedes-Benz C300
Sounds normal to me . If it drops back down when the car is warm then its all good . If it bounces then you could need to tighten the thermo valve in the throttlebody base . These sometimes come loose .
Originally posted by Jocko77 what about low idles..? about 4-700( less than 1)? Im a little worried..
Try looking under your hood. It'll tell you the proper specs for where the idle is on your car. In my GSR, it says 750rpm +/- 50. My in-laws civic says 670rpm +/- 50.
Originally posted by sirGvtec Sounds normal to me . If it drops back down when the car is warm then its all good . If it bounces then you could need to tighten the thermo valve in the throttlebody base . These sometimes come loose .
Sorri i am a noob still learning, but how do you tighten the thermo valve? more instructions please.
Car: Black 96 Civic HatchBack (Mods.), Black 01 Accord Coupe V6 (Stock)
Mods: B18C1 Swap, DC Sports 4-2-1 Cer. Header, Skunk 2 Intake Manifold, MR8 17", Aerospeed Coilovers, Type R Body Kit, and a few other JDM Goodies
I have seen posts where people say to turn the screw on the fast idle thermo valve as well...I looked & I have even taken it apart and have never seen a screw that you can turn. I want to know how it is done as well....I know on the IACV has a screw in it that looks like it can be adjusted, but if anybody has a screw driver with a 5 sided tip (pentagon shape) to adjust it, I would love to know.
Your Fast Idle Valve. I am pretty sure that you have a manual and electronic valve just like me. In this case I would say you may want to change your manual Fast Idle Valve, it will run you roughly $50 from Honda/Acura. The reason your idle may be so high during a cold start is because this valve becomes dirty. Find me anything that says idleing at 3000 RPM's is normal for a Honda, I would like to see it. Your car should idle at 2500 MAX.
‘95 Integra GS-R Hatch Engine/tranny: JDM H22A w/ Factory LSD, HCP Mount Kit, Exedy Organic Clutch, Greddy EVO Exhaust, Custom SS Header, AEM SRI, P72 tuned w/ Uberdata, PWR Radiator, Forbidden Motorsports Short Shifter, Trunk mounted Optima Red Top Battery. Handling/Stopping: Koni Yellow Struts, H&R Springs, Danny Tran Racing Traction Bars, Spoon Rear Strut Bar, ITR Front Strut Bar, Brembo Drilled and Slotted Rotors, Brembo pads, SS Brake Lines, Yokohama ES-100 205/40/17, 17’’ Momo GT2‘s. Ice/Interior: Alpine CDA-9835 deck, (4) Pioneer 6.5'' 3-way speakers (200 watt), 2001 GSR Full Leather, Autometer Bezel Gauge Pod, Autometer CF Oil Pressure gauge, Autometer CF Air/Fuel Ratio Gauge, Skunk 2 Shift Knob, ITR Shift Boot, etc. Future Plans: JDM ITR Front End Conversion w/ Gunmetal H.I.D. Headlights, 17’’ Work Emotion Gunmetal Wheels, ITR Spoiler, OEM optional Side Skirts, Shaved side moldings, Kandy Apple Paint.
