Old 03-01-2004, 10:08 AM   #1 (permalink)
Car: Integra GS-R
Kyo Kusanagi is an unknown quantity at this point
Unhappy Starting Problem
My integra won't start. I would hear a clicking noise and thats about it. I can't figure it out. Is not the battery, or the relay, or the distrubitor. I have to keep on trying over and over until it fires. My friend told me to release the clutch halfway or something whenever you turn it on. Anybody got any 411 on this? Thanks
Kyo Kusanagi is offline
Old 03-01-2004, 03:31 PM   #2 (permalink)
Car: 94 INTEGRA GS-R
Mods: H22 at last!!!
slim9300 is on a distinguished road
Re: Starting Problem
Starter... Coil?
‘95 Integra GS-R Hatch
Engine/tranny: JDM H22A w/ Factory LSD, HCP Mount Kit, Exedy Organic Clutch, Greddy EVO Exhaust, Custom SS Header, AEM SRI, P72 tuned w/ Uberdata, PWR Radiator, Forbidden Motorsports Short Shifter, Trunk mounted Optima Red Top Battery.
Handling/Stopping: Koni Yellow Struts, H&R Springs, Danny Tran Racing Traction Bars, Spoon Rear Strut Bar, ITR Front Strut Bar, Brembo Drilled and Slotted Rotors, Brembo pads, SS Brake Lines, Yokohama ES-100 205/40/17, 17’’ Momo GT2‘s.
Ice/Interior: Alpine CDA-9835 deck, (4) Pioneer 6.5'' 3-way speakers (200 watt), 2001 GSR Full Leather, Autometer Bezel Gauge Pod, Autometer CF Oil Pressure gauge, Autometer CF Air/Fuel Ratio Gauge, Skunk 2 Shift Knob, ITR Shift Boot, etc.
Future Plans: JDM ITR Front End Conversion w/ Gunmetal H.I.D. Headlights, 17’’ Work Emotion Gunmetal Wheels, ITR Spoiler, OEM optional Side Skirts, Shaved side moldings, Kandy Apple Paint.
slim9300 is offline
Old 03-04-2004, 05:30 AM   #3 (permalink)
Red Missile is an unknown quantity at this point
How is the condition of your starter cable? You can do a voltage drop test to see if there is excessive resistance in your power or ground circuits by connecting a volmeter in parallel across the starter wire and cranking the engine. There should be a reading no higher than .3 volts when the engine is cranking. The same can be done for the ground side by connecting the voltmeter from the starter case to the negative terminal of the battery. If the reading is higher than .3 volts you should clean up the connections/replace the cables. If these check out I would start looking at your fuel and spark delivery systems.
94 RS Teg
Red Missile is offline
Old 03-04-2004, 09:12 AM   #4 (permalink)
Car: 1999 Integra GSR
DaWickedOne is an unknown quantity at this point
Have you messed with the distributor...it could be your timing, but if you havent done anything lately to adjust it then its prolly not.
DaWickedOne is offline
Old 03-04-2004, 11:07 AM   #5 (permalink)
Car: Integra GS-R
Well sometimes it seems fine when i start it up and sometimes it doesn't. But I've been thinking mostly it happens because when its cold in the morning. The thing won't start. Sometimes it starts 100% everytime i fires it up. Other i had to push the clutch half-way then it would work. I don't think its my distributor because its new. Haven't tried banging the starter yet. Batteries are new. Spark plugs I've already check nothing wrong.
Old 03-04-2004, 02:12 PM   #6 (permalink)
GunMetal Member
Car: 94' Integra
KruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a lifeKruciaL7integra You need a life
ok slap me in the face and kick me in my ass if this isn't true but my friend had the same problem on his 99 GSR and tried evrything from distributer down to starters,coils,etc. when he took it to Honda/Acura specialist they said his valves were bent. sorry if this doesn't help
KruciaL7integra is offline
Old 03-04-2004, 02:18 PM   #7 (permalink)
It's possible that he needs a valve adjustment, however that wouldn't affect his vehicles ability to start. The valves will make a ticking noise if they are in need of adjustment. Unless it's a major valve problem, like he floated a valve, which would inevitably blow the bottom end, I doubt his strating problem is associated with his valves. And plus, he said the clicking happens before the vehicle is running, this would rule out the valves.
slim9300 is offline
Old 03-04-2004, 02:38 PM   #8 (permalink)
GunMetal Member
Car: 94' Integra
thanks slim for the input...ill keep that in mind
Old 03-04-2004, 02:48 PM   #9 (permalink)
Car: 92 Integra GSR
Mods: Flowmaster exhaust, AEM cold air intake, flashed ECU for 8200 RPM shifts
9GSRtegra is an unknown quantity at this point
IT sounds definetly like a starter problem, check the ground and even the battery. Is there any corrosion on either, clean em up, and try it. If neither of those is the problem, then its time for a new starter =(((
9GSRtegra is offline
Old 03-05-2004, 10:57 AM   #10 (permalink)
Car: Integra GS-R
Thumbs up
Thanks for the help guys. I think the problem is my starter. Its going to die out soon. Thanks again
