Old 11-07-2002, 08:33 AM   #1 (permalink)
Car: 2005 Audi A6/'04 R6
Mods: Nikko Slip-on, Zero Gravity windscreen.(R6)
gsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant futuregsrteg has a brilliant future
Starting Problem?Cranking Noise!
I did a search, but it really didn't give a description of the problem.
My car has been giving me a starting problem for awhile.
Sometimes I have to crank it about 5 times before it starts.
When I try to start it, it makes the noise: Like when you crank it
while your car is already running. It happen after I put in my new
clutch and flywheel. I need help in pin pointing the problem.
In my setup, can you find common cause to this issue?
gsrteg is offline
Old 11-07-2002, 02:56 PM   #2 (permalink)
Insigma is an unknown quantity at this point
sounds like i might have the same problem as you too but i did not need to try 5 times. i released and pressed the clutch again and it starts fine after making that weird noise. scared the hell out of me though.
Insigma is offline
Old 11-07-2002, 06:34 PM   #3 (permalink)
Mods: 4door Teg- 13.8 ls/vtec
When I finished dropping my new engine the starter gave way...sounds like you have a starter problem.
THis is what you can do:
Take out the starter and locate the black housing, inside is a male metal connector.
You can use jumper cables or a voltemeter for this, I used my car battery with jumper cables:
With the black(-) wire place it on the housing of the starter and with the red(+) wire connect it to the terminal located in the black housing.
Caution!! HOld the starter in place and the spindle should POP out out and spin...if it pops out and does not spin you have a starter problem...if it pops out and spins your starter is okay.
Do that first and tel me what happens....if your not sure you can always bring it into honda or Autozone, Pepboys,etc and they can check it for you
______________________
94' integra sedan SOLD
03' Yamaha R1 ltd. Ed.
02' BMW 330 Ci
02' Suzuki GsxR
JAYMAN320 is offline
