Old 10-22-2007, 09:36 AM   #1 (permalink)
NegroDamus's Avatar
NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?NegroDamus you're still here?
Steering rack
Does anyone know if you can just buy the rack ends for a steering rack?
There is some play in one of my wheels when you apply force to the tire left and right. I think it's the ball joint in the rack end.
Other ideas?
"One cannot truly see the light until he has felt the embrace of the abyss."
"Every facet, every department of your mind is to be programmed by you and unless you assume your rightful responsibility and begin to program your own mind, the world will program it for you."
01001100011010010110001001100101011100100111010001 10000101110011001000000101011001100101011011000010 000001001101011011110111001001110011
Reality, the greatest single thing there's never been.
NegroDamus is offline
Old 10-22-2007, 11:29 AM   #2 (permalink)
Car: 2000 Acura Integra GS-R
Mods: AEM V2 intake, HKS catback, Neuspeed lowering springs
AngelSol is an unknown quantity at this point
Lower tie rod end. Get a paint marker from an autoparts store or the arts and crafts section at like Wal-Mart. Go to the autoparts store and get a tie rod end ball joint seperating tool..probably look like a 2 prong fork in the shape of a chisel.. You can usually just rent these. Take your wheel off, mark where your current one is on the threads it screws on to, take the pin out from the bolt on the ball joint end and take the nut off, use the tool and seperate the old one from the lower arm, break the nut loose holding it on and unscrew it. Next, take your new one and screw it on to the paint mark you made on the threads and tighten the nut down. Put the ball joint back through the hole on the lower arm and tighten the bolt to the proper ft/lbs and insert the pin.
Done... if you lined it up with the paint mark and it's on the same as the old one, you shouldn't have to have it re-aligned and your tow should be set the same!
Good luck
I can go from 0-15 seconds in 15 seconds FLAT!!
AngelSol is offline
