Get the DC header because IT IS DYNO PROVEN and Everybody has one, even I did at one time...
Or get the OBX "whatever you want to call it" header and go dyno it and beat the DC piece...
You want an honest answer about the DC header? I had it on a 94 LS and it didn't make any staggering gains it did look nice though and felt slightly stronger, My AEM/CAI made more of an impressive feel though.
Dyno proof is usually first to gain attention and Build quality is second. DC proves itself time and again for it's market segment and the particular application which we are discussing with dyno proven gains. Build quality is good and competitive.
OBX on the other hand is second rate in comparison.
So go ahead and get it and tell us what you think. I am Not mocking you. But, please post your results after the install and some dyno numbers...
If all you can afford is an inexpensive replacement then so be it, just don't be upset if it provides nothing more than stock and possibly less as for gains and rusts and falls apart prematurely...
The choice is yours but, if you think that $300. to $400. is alot then you will run screaming in fear "IF" you had to choose a serious header for race applications IE: SMSP, Hytech, Spoon, Toda.....
Good luck,
A.
