1st: You NEED to educate yourself about Springs and spring rates, applications and how they effect the ride both in, quality and performance.
2nd: You NEED to use the: SEARCH function, because this has been covered about 1,000,000 times in the last 6 months.
Then you will be able to make an educated decision as to what you want and who actually makes the springs that best fit your needs.
A good place to start may be the Suspension forum HERE.
Good luck,
A.
