Old 11-07-2002, 06:43 PM   #1 (permalink)
Mods: 4door Teg- 13.8 ls/vtec
tech wrench Swap done, yet ran into some problems
Hey guys, I just finished dropping the engine into my teg....but heres the problem.
The idle is very rough, and the car doesnt enable me to rev past 4500rpm...what do you think is causing this?
This is what I have so far:
-97 b18b
-I used my existing engine harness and cut and soldered wires inorder to use the connectors
-OBD1 LS ecu
-Its not my o2 sensor, I just chnaged that
-NO CEL are being thown
-I tuned the idle screw located below the throttle lever and adjusted the idle screw according to spec
Thanks in advance, I hope someoe can help me
JC
______________________
94' integra sedan SOLD
03' Yamaha R1 ltd. Ed.
02' BMW 330 Ci
02' Suzuki GsxR
JAYMAN320 is offline
Old 11-07-2002, 07:32 PM   #2 (permalink)
Car: 92 Honda Prelude Si
Mods: Stock
skidtron89 is an unknown quantity at this point
Check your oil and coolant levels and then your distributor is morethan likely your problem you will need to take a look at the wavefrom shapes coming of the sensors with an oscilloscope.
skidtron89 is offline
Old 11-08-2002, 09:19 AM   #3 (permalink)
Nguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphereNguyen In the rep troposphere
WAYYY OT, because I don't know your answer...
BUT Wow Jay asking a quesiton...this has got to be a rare rare occasian..haha usually he has most the answers to everything...
Good luck to you and your new engine,
Jason
Nguyen is offline
Old 11-08-2002, 10:13 AM   #4 (permalink)
Car: Acura Integra LS 2001
even though i'm sure you did, i would check and double check that ecu wireing. cause wouldnt that be the only thing that would effect your rev limit? since your not throwing a CEL? and even if you were for that matter?
you sure the ecu was working?
just a few things to think about. doubting myself only cause of who i'm giving this info to.
good luck!
and btw, what happened to the b20/vtec idea?
hope everything works out.
eppo is offline
Old 11-08-2002, 07:28 PM   #5 (permalink)
I am using a OBD1 LS ecu, Can the PCV system be the one causing this?
The hoses are totally different when compared to a gs-r. DO I need to cap anything off? Do I need to place check-valves anywhere?
Does anyone have a hose diagram?
The pin outs are different when compared to OBD1 to OBD2 engine, of course.
So inorder to fix this I would have to buy a OBD2 wire loom/jumper harness and use a OBD2 engine harness and OBD2 non-vtec ECU, CORRECT?
Is there any other way around this? What do you think?
02' BMW 330 Ci
02' Suzuki GsxR
Old 11-08-2002, 09:45 PM   #6 (permalink)
randyman's Avatar
Car: 94 acura integra
randyman is an unknown quantity at this point
sounds like a distributor problem to me too. have u tried swapping distributors? i'm not too sure about the work that u've done with the harness. ur prolly better off getting either an ecu jumper from obd1-to-obd2, or get an obd 2 ls ecu and get a jumper for the obd 2 ecu.
if anything, have a friend with a teg come over and look at his/her hoses. diagrams in the manual are almost confusing especially with where each hose goes.
goodluck.
1994 Acura Integra B20/VTEC (SOLD)
00 Mercedes Benz M-CLass
02 Porsche 911 Turbo
01 Mitsubishi Eclipse
...Yes, I'm an arms dealer!
randyman is offline
Old 11-09-2002, 01:08 AM   #7 (permalink)
Car: Sound Experience
Integra707 is an unknown quantity at this point
Is it just a b18b? Into an Integ? Or what exactly is the setup?
Integra707 is offline
Old 11-09-2002, 01:37 AM   #8 (permalink)
Car: 1992 Frost white honda Civic VX
Mods: Exterior:JDM headlights, VISION corners, JDM tail lights, Carbon Fiber front lip, Carbon Fiber hood, carbon fiber VISION side mirrors, gold 16 x 7 ADVAN Racing RG wheels, Carbon Fiber duckbill wing Interior: Stock blue interior converted to black
AcuraBro is an unknown quantity at this point
DISTRIBUTOR
goodluck.
Word to that, brother Randy.
Definatly the distributor. Take the distributor off and see if you find and reddish-brown dust. This is a tell-tale sign that it's fried. I've had it happen to me before.... a couple times.
'96 Integra Turbo @ 15psi built by me in my garage.
12.483 @ 113.96mph @ 5830ft
daily driver *STOLEN 12/27/02*
'92 Honda Civic VX
AcuraBro is offline
Old 11-09-2002, 02:18 PM   #9 (permalink)
Car: red 94 integ gsr
allmotor_integ is an unknown quantity at this point
like Randyman stated earlier try purchasing a Skunk2 obd2 to OBD1 conversion kit,
my friend had a rough idle awhile back it was because his distributor coil was skipping gears ......or yours could be burnt
1995 Mitsubishi Eclipse GS <sold>
1996 Acura Integra LS/VTEC *wrecked* =
1994 Acura Integra GSR-Turbo 2.0 ltr *stolen* r-81
1994 Acura Integra H22a ~SOld~ =
2001 Acura Integra Type R #582
future project car:
datsun 510
-sr20det
allmotor_integ is offline
Old 11-09-2002, 03:33 PM   #10 (permalink)
alrighty than, Ill check up on the distributor.
Thanks for the help guys
02' BMW 330 Ci
02' Suzuki GsxR
Old 11-12-2002, 05:01 PM   #11 (permalink)
Car: 1999 Acura Integra LS
I doubt this will help, but if you still need an OBD2 LS ECU you can have mine in about 6 weeks hehe
skibbs is offline
