Old 03-05-2004, 02:50 PM   #1 (permalink)
Car: 92 Integra GSR
Mods: Flowmaster exhaust, AEM cold air intake, flashed ECU for 8200 RPM shifts
9GSRtegra is an unknown quantity at this point
Tires on an integra
Im looking at Rota Slipstream 15 inch rims with 205 tires but Im worried about fitment. Currently I have 195 tires on my car and don't know if the 205's will fit right.
Is what the rear looks like with the 195's and 14 inch rims on...would I need tolift it up a bit? Im currently lowered about 2.5 inches.
9GSRtegra is offline
Old 03-05-2004, 03:38 PM   #2 (permalink)
Uprising is infamous around these partsUprising is infamous around these partsUprising is infamous around these partsUprising is infamous around these partsUprising is infamous around these partsUprising is infamous around these parts
It looks like you currently have 195/65/14 (pretty "chunky" sidewall), so if you went to a 205/55/15, or 205/50/15 it should fit about the same as your current setup. The smaller the middle number, the shorter you're sidewall will be.
Uprising is offline
Old 03-05-2004, 03:42 PM   #3 (permalink)
Car: 92 Integra GSR
ya they are 195/65's....I hate the sidewall on them too =P Im just hoping that the wider wheel will tuck in, I may lift it up so the rear isn't tucked tho, my cars about a half of a pop can off the ground, and its hard to get out of the lip in my driveway (about 2 inches)
Old 03-05-2004, 06:39 PM   #4 (permalink)
If you have been in the import scene, or even the wheel/tire market long enough then you would realize that the 205/50/15 size is rather popular and used quite a bit.
Although there may be some difference in tire dimensions, its not too much to throw anything off. You'll be fine with 205/50/15's.
female four is offline
Old 03-05-2004, 07:26 PM   #5 (permalink)
Car: 92 Integra GSR
Thanks for the replies =) I really don't know much about tires cause Ive never really spent the time to distinguish between seperate types. =(
Old 03-05-2004, 07:32 PM   #6 (permalink)
You should really make an effort to understand them. I too was wondering what the markings on the tires mean. All I knew back then was they all fir on a certain size rim and the 195 or 205 meant the width of the tire.
A good start is Tire Rack's Tire Tech and the first thing that you should familiarrize yourself with is this page on Tire Rack's site.
Have fun and read up! Learning is cool when you apply it to you car!
Old 03-05-2004, 07:37 PM   #7 (permalink)
Add this calculator to your stickies to figure out wtf is going on with different tire sizes:
http://www.rx7turboturbo.com/robrobi...e_diameter.htm
and another just for kicks;
http://www.powerdog.com/tiresize.cgi
You're looking for overall outer diameter when plus sizing besides width and offset and if it will actually fit in your wheel well.
1Greyteg is offline
Old 03-06-2004, 10:50 PM   #8 (permalink)
Car: 2000 Acura GSR
Mods: AEM CAI, Kakimoto R cat back exhuast, K2 HID lights, System, Konig Theory, H&R sport springs, Koni Yellow's, Polyurethane Bushings, Skunk 2 Camber kit
One_Vtec_18 is an unknown quantity at this point
Will I run into any problems if I'm using a 215/40 R17 tire on my 2000 GSR. Some guy is pushing really hard at this tire store to sell me this size, I used to have 205/40 R17 before on my rims. BTW my car is dropped with the wheels tucked in. Thanks
One_Vtec_18 is offline
Old 03-07-2004, 08:41 AM   #9 (permalink)
acuradriva's Avatar
Car: 98 GS-R
Not really. the middle number is a % of the 1st number so if you are going with a wider tire the side wall could be close to the same or even wider depending on how much wider you are going.
acuradriva is offline
Old 03-07-2004, 10:50 AM   #10 (permalink)
Car: 1995 Acura Integra GSR
Mods: *See the sig*
*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere*Vtec@8000RPM* In the stratusphere
i have heard of rubbing problems with the 215 size esspecially with GSRs that are dropped....
!!stick with 205 and dont give in the the salespersons bullshit!!
*1995 Acura Integra GSR* ***STOLEN 7/2/07***
Black On Black, 98+ Front Bumper w/ ITR Lip, Timing Advance, JDM P73 ITR Pistons, AEM CIA, Port & Polished IM w/ Hondata Gasket
DC Sports 4-2-1 Header, Random Tech Cat, Apexi N1 Cat-Back, ACT Street Clutch, B&M Short Shifter, Spoon Knob
Eibach Sportlines, Tokico Blues, Skunk2 Camber Kit, Powerslot Rotors, Hawk Pads, New OEM Calipers, Earls Stainless Steel Brake Lines
172hp @ 7750rpm
Thanks to xturbo420x for the sig!
*Vtec@8000RPM* is offline
Old 03-07-2004, 01:13 PM   #11 (permalink)
Car: 2000 Acura GSR
Good looks on the info.
