i dont think gsr pistons are much more compression than the ls ones,
but we had a set of type r pistons that we sent out to have a custom set made from them and went up to 11.1:1 in an ls. they worked fine . the bore is the same , but i think you might need diff lenghth rods. im not sure if the stroke change at all
They will work, but I believe the rods have to be slightly modified. For the piston to connect properly. I am sure there was a similar post on this already.
I have an LS Integra, would putting these pistons in make a difference, is it a worthwhile install. What kind of gains are there from using these pistons over the stock LS
2000 Black Integra LS
AEM - CAI
AEM - Underdrive Pullies
DC-Sports - 4-1 Header
DC-Sports - Short Throw Shifter
5 Zigen - Cat Back Exhaust
TestPipe.com - 2.25" Test Pipe
Skunk2 - OBD2/OBD1 Conversion
95LS P75 OBD1 ECU
EBC - Redstuff Brake Pads
Mugen - 8 Point Front Strut Tower Bar
OBX - 4 Point Rear Strut Tower Bar
Neuspeed - Sport Springs
Rota - 17" Gunmetal Subzeros
Re: if you don't know...don't post and please DON'T GUESS!!!
Originally posted by Tuan
this is completely wrong.
you can use b18C1 , b16B, and B18C5 pistons on an LS rod as long as you mill the small end of the rod by 0.7mm on each side and then shot peen the rod to regain the surface tension strength. The small end of the LS rod is too fat for the GSR and "R" pistons but you CAN make these pistons fit.
you can use JDM b16A (PR30) and USDM b16A (PR3) pistons directly on LS rods without having to mill the small end of the rod.
wu racer. just go somewhere. dont state your opinions if you dont know what your talking about.
there are alot of knowlegable people on this board, tuan being one of the most that i know of . . . . dont second guess them . people like you make things difficult
tuan i remember you posting a web site a while back...i acutally think it was at HV, and you could mix blocks, heads, and pistions and it would yeild a compretion rationg for the B series motors (all honda parts, no aftermarket), but now the site has been down for some time. you don't happen to have any similar sites do you?
it worked...yay i love that thing, it makes me get all these frankinstine motor ideas going though my head, none of which i will never do, but a guys gotta dream every once in a while.
