Well since this list is in a lot of threads but is impossible to find because it doesn't have its own thread... here it is.
Stock curb weight: 2640lbs as listed by Acura for '98 LS 3-dr 5-spd (full tank and fluids)
My curb weight: ~2488lbs (full tank and fluids)
Raceday weight: 2353lbs as verified by corner-weighting scales (with typical amount of fuel held in race, about 1/4 tank)
Front
Air conditioning system removal (-46lbs)
Power steering removal (-17lbs)
Carbon fiber hood (-16lbs)
DC Sports header (-15lbs)
Hawker Genesis battery (-13lbs)
ACT ProLite flywheel (-9.5lbs, rotational)
Intake resonators/piping removal (-7.5lbs)
Cruise control system removal (-4.5lbs)
Intake manifold bracket removal (-2.5lbs)
Glovebox metal panels removal (-2lbs)
Front brake dust shields removal (-0.5lbs, unsprung)
A’pexi S-AFC (+0.5lb)
Type R front lip (+2lbs)
Front strut brace (+2lbs)
Limited slip differential (+3lbs, rotational)
Prelude VTEC calipers (+6lbs, unsprung)
Prelude VTEC rotors (+6lbs, rotational and unsprung)
Total: -114lbs
Middle
Sound deadening tar removal (-12lbs)
Subwoofer wiring removal (-4.5lbs)
Mud and door guards removal (-4lbs)
Exhaust heat shields removal (-2lbs)
Suspension Techniques swaybars (+5lbs)
Total: -17.5lbs
Rear
Trunk floorboard removal (-8lbs)
Rear wiper and motor removal (-3.5lbs)
Honda S2000 antenna (-1.5lbs)
Center brake light removal (-1lb)
Rear brake dust shields removal (-1lb, unsprung)
Trunk brace (+1lb)
Skunk2 rear strut bar (+2lbs)
Total: -12lbs
Total: -144 lbs (approx. –123lbs from front of car, -21lbs from rear)
Total weight: 2432lbs (1105kg) w/low fuel, 2488lbs w/full tank
Weight distribution improved from approx. 63/37% F/R to 61.5/38.5%
Autocross trim
Remove spare wheel/tire and jack (-25lbs, rear)
Remove rear seats, seat belt buckles, trunk mat, cargo cover, and carpet (-36lbs, rear)
Wheels/tires lighter by 2lbs per corner (-8lbs, middle, rotational and unsprung)
Remove floormats (-10lbs, middle)
Total: -79lbs (approx. -8lbs from front of car, -71lbs from rear)
Raceday weight: 2353lbs (1070kg) w/low fuel
Corner weights WITH driver (169lbs):
811---767
495---449
Cross-weights: 1260lbs and 1262lbs
See this thread for more info on corner-weighting:
Corner-weighting your car with coilovers
